Holley Projection Vs Crossfire injection
Old Apr 9, 2007 | 06:48 PM
mrmmoore's Avatar
mrmmoore
Default Holley Projection Vs Crossfire injection
Has anyone tried the Holley projection system on a 84 Vette (auto) with crossfire injection? Would there be any gains? I know that it would require changing of the intake. Would I just be better off getting my throttle bodies reworked with better flowing injectors?
Old Apr 9, 2007 | 07:21 PM
ps374's Avatar
ps374
You might want to check the weiand web site about the Xram for your crossfire. My 84 was modified by the last owner with this set up. Weiand promises 50 plus horsepower (I doubt it) maybe more like 25. The last owner claims a TPI had nothing over his crossfire with this set up. Since I never drove a TPI I could not tell you if that is true or not but the car does pull strong off the line. You may also want to up grade the fuel pump to a 85 if you deside to go with this set up. I think there is a web site called "Crossfire injection vault" which can give you more info should you decide to take the plunge.
Old Apr 9, 2007 | 08:25 PM
CFI-EFI's Avatar
CFI-EFI
The X-Ram doesn't do as much for a stock engine as a GOOD porting job on the stock manifold. A 1985 fuel pump will gain you nothing over a good stock pump. Reworking throttle bodies and better flowing injectors won't do anything for you until you get the weak link, intake manifold, working better. The most prevalent problem with the Crossfire for performance IS the manifold. You can do quite a bit with what you have, for little money, but because the Holley set up does include a manifold, it should do a LOT for performance. Of course it won't be a Crossfire any more, if you care.
RACE ON!!!
Old Apr 9, 2007 | 08:38 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
A couple of good pages to read.
http://www.swko.net/~lionsden/crossfire.htm
http://www.technovelocity.com/chevyh...rt_polish.html
Old Apr 9, 2007 | 08:47 PM
Pete K's Avatar
Pete K
I cannot comment on the direct comparison the cross fire vs projection. We have installed projection on a few carbed street cars and were very pleased with the outcome. On a well tuned carbed 350 camaro, we saw no et benefits. Both ran the exact same et. We did gain 1 mph in the 1/4 mile, cold starts were improved and gas milage went up 3 mpg.
Long story short, we were pleased with the projection.
Old Apr 9, 2007 | 09:44 PM
JLeatherman's Avatar
JLeatherman
Ken on the crossfire forum is running a Holley 454TB setup with a 7747 with HAM and EBL. I believe he is very pleased with the results. Try posting on that board under the alternate induction section.
http://crossfire.homeip.net
Old Apr 9, 2007 | 09:54 PM
bogus's Avatar
bogus
the projection will give you more tuneability. but it has it's limits...
Old Apr 10, 2007 | 01:12 AM
xrcrx's Avatar
xrcrx
A well ported Crossfire manifold will work much better than the X-Ram. I'm running a ported intake and 1.6 roller tip rockers on my 127k mile 84 and running 14.3's at 96mph.
Old Apr 10, 2007 | 11:48 AM
CFI-EFI's Avatar
CFI-EFI
I'm running a ported intake on my 165k mile 84 and running 13.7's at 98+ mph. No 1.6 rockers.
RACE ON!!!
Old Apr 11, 2007 | 09:09 AM
Dominic Sorresso's Avatar
Dominic Sorresso
I'm running a ported Xfire manifold with a best ET of 13.3 and best MPH of 105.
Old Apr 12, 2007 | 12:11 AM
mrmmoore's Avatar
mrmmoore
Great information, Looks like I am going to be doing some work on my crossfire manifold... Thanks
Old Apr 12, 2007 | 11:13 AM
Rohn's Avatar
Rohn
I went to the dark side and removed the crossfire in total and run a Holley Projection manifold with a GM 7.4L TBI unit with larger injectors.
Prior to the above conversion i had the Xram and was disappointed with the drivability. I was and am still of the opinion there were fuel distribution problems due to a cold plenum. raw gas found in xram plenum as well as a couple plugs very rich and maybe four plugs correct on color. The design of Xram is very compromised and needs to be. if you reside in a warm climate it may work well. I do not(wisconsin).
Old Apr 12, 2007 | 02:41 PM
CFI-EFI's Avatar
CFI-EFI
And nothing else???
RACE ON!!!
Old Apr 12, 2007 | 02:49 PM
xrcrx's Avatar
xrcrx
Dominic has a mod or two besides the intake!
Old Apr 12, 2007 | 02:57 PM
Dominic Sorresso
As you can see by my sig.
84 Xfire Z51/ZF-6 Black Tag
Extrude Hone/CompCamsHydRlr/
TFS 23deg/MSD/TPIS headers/MagnaFlow cat-back
310rwhp/350lbft rwtorque
Old Apr 12, 2007 | 05:11 PM
ben73's Avatar
ben73
I ran a ProJection throttle body for a short while.
I didn't really like it, but it was one of the old ones with the crap injectors, and didn't have the progressive linkage that the later ones have.
I also adapted a spare air cleaner to fit so it looked stack, and the cold air ducting was still functional.
It ran fine, but I removed it as I enjoy the challenge of making the Crossfire work instead.
There is nothing to gain from this swap. I would not bother again.
Bored TB's and BBC injectors on an XRam will supply all the air and fuel you can use.
Here are a couple of pics.
Old Apr 12, 2007 | 10:56 PM
scooter18155's Avatar
scooter18155
nice work on the air cleaner assembly. do you still have it? i might be willing to take off your hands if ya do and want to part with it.
To Holley Projection Vs Crossfire injection
