32 Valve LSx Heads
Old Apr 11, 2007 | 03:38 PM
JAKE's Avatar
JAKE
Default 32 Valve LSx Heads
Have you guys seen the newly released 32 valve LSx heads?
http://www.ls1lt1.com/forum/showthre...8494#post78494
Just thought you might be interested.
Jake
Old Apr 11, 2007 | 04:36 PM
danziger's Avatar
danziger
Very sick indeed, but I wonder how much they will outflow a nice set of ETP/AFR/Trick Flows etc...
Old Apr 11, 2007 | 05:23 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
From what I understand about 4-valve combustion chambers, it isn't increased maximum flow (at 100% lift) that gives the 4-valve its advantage, but greatly increased flow during the first 75% of lift and the last 75% of valve-closing events.
Greater TOTAL flow volume during valve-open time, rather than just peak flow rates at max lift.
Sounded good to me..................
Larry
code5coupe
__________
I ain't easily impressed....
Old Apr 11, 2007 | 05:28 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Great, like they're not hard enough to beat already! Nice though, they makes me want an LS engine more than ever.
Old Apr 11, 2007 | 05:58 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
About as worthless as the 4 valve heads for the LT1 they did a few years ago.
Old Apr 11, 2007 | 05:59 PM
Zix's Avatar
Zix
Yep...did they ever really get those things working??
Old Apr 11, 2007 | 06:08 PM
danziger's Avatar
danziger
I'm just wondering if the performance will be anywhere near justifying the cost. There are some sick flowing LSx heads out there that maintain good velocity. I guess on a max-effort car it may be worth it, but to us "regular Joes" a good set of 2V heads would be the logical choice...
Old Apr 11, 2007 | 06:10 PM
billybonesmusic's Avatar
billybonesmusic
he he, would be nice sitting on top of the lsx 6 block!!!
Old Apr 11, 2007 | 06:40 PM
Zix's Avatar
Zix
Well, peak flow numbers, yes...there are come great flowing LS heads...but I would think that if these were done correctly they will have MUCH better mid-lift numbers as well as peak numbers.
Old Apr 11, 2007 | 07:11 PM
Jeffvette's Avatar
Jeffvette
You would see them on every Corvette, F-body, Impala ever made. I expect nothing greater out of the LS1 version.
The LS1/2 heads flow extremely well, even a stock 243 casting flows well enough to reach 450 RWHP on the low end scale and still make great power down low.
Old Apr 11, 2007 | 09:38 PM
cv67's Avatar
cv67
St. Jude Donor '05
Those heads are for the big-buck gotta have and wow crowd, their stuff isnt cheap. I can cross the street and walk there in two minutes.
Only good thing about the 4 valver is you dont need a bunch of cam timing to make power, just deep pockets. Interesting stuff. I will say the test cars I see running back and forth with their heads get some stupid rpm, and get it quick.
Old Apr 11, 2007 | 09:50 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Why bother Just get an LT5
Old Apr 11, 2007 | 10:39 PM
VenkmanP's Avatar
VenkmanP
Brett Bauer has been reworking a set (LT1 32V for those who aren't following closely...) for a customer who has given him basically an open checkbook. The effort to make them actually work is >> the cost of the heads themselves.
Old Apr 11, 2007 | 11:20 PM
Jeffvette's Avatar
Jeffvette
So roughly 7K for heads and to get them to run correct.
Old Apr 11, 2007 | 11:28 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Then you have something that will hold it's value and you don't have to worry about pushrods.
To 32 Valve LSx Heads
