Throttle Body Size Question
Plus, if you have an LT1 car, the openings in your intake manifold are only 52 mm, so you'll basically be putting a 52 mm TB on your car.
When the air coming out of the 58mm throttle body hits the sharp edges of the 52mm intake openings it will create turbulance which will screw up air flow....
IMHO this is the main reason the 58mm throttle body has gotten such a bad rap...
My 58mm throttle body stays on my intake manifold modded with 58mm openings!!!!!
I can't imagine that with all the obstructions in the MAF and TB itself that at little restriction at the plenum could affect air flow enough to affect performance.
Same day; 18 runs on stock TB , 12 runs on 58mm.
No changes except for resetting TPS.
Same ET / mph.Same 60 ft times which proves no loss of bottom end as frequently stated
Excellent off idle response ,SOTP felt better but not shown in time cards.
Only downside was harder to "tickle" the throttle off idle like when moving slowly forward in traffic but possibly due to very stiff spring on BBK TB.
By NO means a good " bang for buck" investment on a stock or mild engine; there are other mods that will give you more improvementfor your $$$, but your engine will not die
Also i hooked up my laptop Winaldl, before and after, Blm's reading low (Rich) with 58mm TB and high (perfect 128 ) with a 52mm TB BBK. So i like BBK than ASM but iam biased, ASM looks nice and lot better than BBK though. BLM's with 58mm are 110-122 which is too rich with same Fuel pressure (52 and 58).
The only difference aSM comes with IAC custom housing, may IAC pintle not extending much dont know i will figure out in a day or 2.
But i saw mustangs 4.6L comes with 59mm or 61mm Twin TB stock, and they upgrade thiers to 65mm or 69mm TB.
If u still have Stock TPI plenum i recomend sending to TPIS to port for 58mm TB thats 100 bux worth it, they did mine 2 yrs ago it was worth.
OR u can do urself, http://www.geocities.com/jgkov/PRPort.html.
sami
