Need Motor Info
Old Apr 12, 2007 | 09:47 PM
BoeBX's Avatar
BoeBX
2nd Gear
Default Need Motor Info
I have no markings to go by accept a sticker faded with 5.7 liter on it.What other way is there of telling what motor and horse power my 89 c4 has
Old Apr 12, 2007 | 10:28 PM
clf93lt1's Avatar
clf93lt1
stock is a l98, 240 hp 340 tq
Old Apr 13, 2007 | 12:34 AM
ozvette87's Avatar
ozvette87
89 had 245hp if a coupe, 240 if a Vert
Old Apr 13, 2007 | 05:43 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default what engine
You have to learn to read backwards first.
Got it down pat?
Ok, get a mirror, move the spark plug wires a little at the back of the block, use a flashlight, and point it down.There's a casting number on the part of the engine on the top of the bellhousing flange. you should see 5.7 cast into the block back there also.
If there's a little cast in tag that says made in mexico, it's a replacement engine, and all bets are off except it is a 350 block.
To determine the heads, pull a rocker cover, and look for the casting numbers at or near the valve spring bases. the last three numbers gives the head type.
Call Chevrolet, and ask them what the casting numbers fit.
Old Apr 13, 2007 | 06:03 PM
clf93lt1's Avatar
clf93lt1
you can check casting# here. http://www.mortec.com/
To Need Motor Info
