Header ground clearance
Old Apr 13, 2007 | 06:30 PM
jimmers's Avatar
jimmers
Default Header ground clearance
I recently bought a set of headers to put on my soon to be rebuilt engine. I got a call from my mechanic today saying that the headers will not work because of the ground clearance. I didn't really believe him, so I went down to check. With the headers installed, there is only a 2 inch clearance between them and the ground. He recommends that I don't install them because I will be constantly scraping and bending them. My question to you guys is how far are your headers from the ground? Do they hang down lower the stock intake manifolds? The headers are Doug Thorleys. Thanks!
Old Apr 13, 2007 | 06:37 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by jimmers
Do they hang down past the stock intake manifolds?
Are these headers specifically for a C4 Corvette? They aren't right, for whatever reason.
RACE O!!!
Old Apr 13, 2007 | 06:54 PM
geezel's Avatar
geezel
My TPIS headers are only 1" or so lower than the undercarriage.
jimmers's Avatar
jimmers
RACE O!!!
Apparently they were made for a C4.
Old Apr 13, 2007 | 07:16 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
There's no way this is right. All of the headers I've had experience with for C4s have virtually as much clearance as the stock stuff. Check your PM box.
Old Apr 13, 2007 | 07:19 PM
CFI-EFI's Avatar
CFI-EFI
You don't sound very positive. Did you buy them new? Did you see a listing for the part number you bought showing the C4 application? Are the headers stamped with the part number you are billed for? If they were used, then...
Doug Thorley is a better product than that. The headers should have decent ground clearance, if your frame and engine mounts aren't messed up.
RACE ON!!!
Old Apr 13, 2007 | 07:31 PM
jimmers's Avatar
jimmers
RACE ON!!!
The frame and engine mounts are fine. I guess they arent made for a C4. Thanks for the input, I didnt think this was right.
Old Apr 13, 2007 | 08:02 PM
86PACER's Avatar
86PACER
Is your car lowered?
These are my Hookers. Mine is not lowered. It sits at stock ride height in these pics. I've never scraped them on any speed bumps.
Old Apr 13, 2007 | 08:08 PM
rel3rd's Avatar
rel3rd
I'd have to scrape my floorpans to scrape the Hedman Elites on my car...
Old Apr 13, 2007 | 08:12 PM
86PACER's Avatar
86PACER
Yeah, mine are pretty much even with the oil pan and floor boards as you can see. Before I installed them, I contacted just about every Corvette speacialty shop found in an issue of Corvette Trader. They all told me a bunch of horror stories about long tubes on these cars with installation and ground clearance. Every one of them recommened that I stay away from long tubes. It all turned out to be a bunch of BS, at least with the Hooker headers.
rel3rd, does that ball style header flange connection seal pretty good?
Old Apr 13, 2007 | 08:18 PM
rel3rd's Avatar
rel3rd
Perfectly sealed.
I can't believe Hedman's are the only Corvette headers that have the ball & socket collectors. The 5.0 Mustangs have used these type header flanges for several years...even stock. That little option all but "sealed" the deal for me buying them. Although yours look to be nicely sealed, I cannot stand the 3 bolt flat flange that Hooker uses. And I wasn't too keen on a slip-joint like TPiS uses, so it all worked out in the end.
Old Apr 13, 2007 | 11:10 PM
jimmers's Avatar
jimmers
My vette isnt lowered at all. Thanks for the pics guys. The headers I have are so close to touching the ground its not even funny. I'll have to invest in a new set now.
Old Apr 13, 2007 | 11:11 PM
jimmers's Avatar
jimmers
86PACER are those longtubes you have?
Old Apr 14, 2007 | 01:30 AM
86PACER's Avatar
86PACER
Yes, Hooker 2151's.
Old Apr 14, 2007 | 04:56 PM
rel3rd's Avatar
rel3rd
Hopefully, the seller is genuine. I would most definitely take him up on his offer made in your WTB post...I had almost bought them myself a few months ago. Good Luck.
Originally Posted by Corvette Kid
You're welcome. I'm heading to the UPS store now. I think you'll like them, I hope you will. If you don't I'll buy them back. I know they're just headers but I think they're about the coolest looking set I've ever seen for a C4. I like the way the pipes are routed.
Old Apr 14, 2007 | 07:23 PM
86GoldProject's Avatar
86GoldProject
rel3rd what size collector is that?
Old Apr 14, 2007 | 07:40 PM
Corvette Kid
You're too late, I already have. They're on their way back here now. Obviously had I realized this problem, I wouldn't have sold them to him to begin with.
To Header ground clearance
Old Apr 14, 2007 | 07:46 PM
CFI-EFI's Avatar
CFI-EFI
You sure can't beat that for doing the right thing. Three cheers for Corvette Kid.
RACE ON!!!
Old Apr 14, 2007 | 07:47 PM
c4cruiser's Avatar
c4cruiser
rel3rd-- Are you running cats with the headers? If so where are they?
I want to get a set of Elites and your pic answered a question I had regarding how far back the collector was from the block/bellhousing flange. I want to run some cats with a true dual setup on mine.
Also, do you have an 02 sensor on the headers anywhere?
Old Apr 14, 2007 | 08:39 PM
LD85's Avatar
LD85
When you lower a car, the chassis height stays the same, right?
Only the body becomes lower,, you would have to lower your engine mounts to get the engine to become lower
