305 engine ?
Old Apr 16, 2007 | 07:49 AM
Slalom4me's Avatar
Slalom4me
Originally Posted by tiffsc4vett
All the way around the intake, the size of a nickel laying flat. It just
is not sitting flat at all.
On the 305, does the valley below the intake manifold look like this?
Or like this?
Old Apr 16, 2007 | 08:22 AM
JLeatherman's Avatar
JLeatherman
Uhhhh, what am I looking at here?
Old Apr 16, 2007 | 08:48 AM
Slalom4me's Avatar
Slalom4me
Potential obstructions that would interfere with the underside of the
Crossfire intake and prevent it from settling fully int the intake valley.
The second photo shows a valley configured for a roller cam with the
retainer spider mounted on risers cast in the block. If the underside
of the Crossfire has a heat shield or is cast in such a way as to require
the full depth of a non-roller block, then it may not fully seat in a
roller block.
I am aware that '85 Trans Ams did not ship with 305's configured for
roller tappets.
Old Apr 16, 2007 | 11:52 AM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by Slalom4me
If the underside of the Crossfire has a heat shield or is cast in such a way as to require the full depth of a non-roller block, then it may not fully seat in a roller block.
There is a small heat shield on the right side of the intake manifold that shields the exhaust passage that travels from the crossover, heat riser, port in the right head to the EGR valve located in the right rear of the intake manifold. It would in no way interfere with roller lifer hardware, and if it did, Nothing would keep the manifold from touching the head on the left side.
RACE ON!!!
Old Apr 16, 2007 | 11:58 AM
jimmya's Avatar
jimmya
if you don't figure it out take some good pics and im sure we can get you an answer.dumb question but you do have the valvecovers off don't you, ive seen this causing the same problem.if you can get the ports sitting flat, silicone the front and back no matter what the gap.
Old Apr 16, 2007 | 11:59 AM
Slalom4me's Avatar
Slalom4me
Thanks.
Seemed like a possibility. Guess not.
Old Apr 16, 2007 | 04:02 PM
LayZ's Avatar
LayZ
The 305 is a boat anchor please don't keep it in a vette. If you need it to go around in, cool. True the 305 is essentialy the same but it was built for smog not power. I can't recall the entire conversation i had with a friend but the jist was: if you bored it and re stroked it you could have a 327 engine and it could make 300 or so horse. My retorte was ok but if you did that to a 350 you could have 400+ horse, which would you rather do?
Old Apr 16, 2007 | 05:33 PM
tiffsc4vett's Avatar
tiffsc4vett
It looks like the first block.
I know it sound crazy to some of you but im telling you the truth this thing is not sitting flat at all.It looks to me like i would need the intake machined down in the front and the rear for this to work.
I going to work on it this weekend and ill take some pics.Like i was saying maybe Im not seeing something but ill look it over.
Old Apr 16, 2007 | 06:10 PM
86GoldProject's Avatar
86GoldProject
Please take pics of the engine, mainly the intake ports on the heads and the lifter valley, and the bottom of the intake, there has to be some obstruction beause like everyone else said it should bolt right up unless the manifold is horribly warped or something.
Quote:
Originally Posted by coupeguy2001
The cam might have to be changed on the 305 due to it being TPI motor, and going into a throttle body car.
Quote:
Leave the cam alone. It is well suited for what you are doing.
Do you know what 305 you have? Its either a LG4, which was the low performance 305 with a small cam and a 4 barrel, the L69 which was the "High Output" 305 with a reasonable cam and a 4 barrel, or the LB9 which was the TPI with the same cam as the L69. The specs for the "HO" cam were .403 int .415 exh and 202/206 duration w/ 114.5 lsa... the LG4 cam was total junk but I don't recall the specs..
Old Apr 16, 2007 | 09:31 PM
nitecruizer's Avatar
nitecruizer
Originally Posted by snowmaker2000
Won't the car be pig slow with a 305? ....
HOW DOES A PIG RUN? LOOK OUT ZR'S
Old Apr 16, 2007 | 09:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The gap is the size of a nickel laying flat. The gap is at the back and the front of the block
Pick up a top end FelPro gasket set at AutoZone, lay the intake gaskets onto the heads and drop the intake base into place.
You should then see about a 1/4" gap between the bottom of the intake and the front & rear lands of the block. These locations are where the RTV will go to deal the base.
The 305 will look more like this. The lower pic is of a roller cam block; you can see the lifter spiders in the valley..
Old Apr 17, 2007 | 01:26 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Sounds like that's what she's overlooking: the RTV.
larry
code5coupe
___________
I ain't easily impressed....
Old Apr 17, 2007 | 05:51 PM
  #33
tiffsc4vett
Its the high output engine. I will get back to you guys on sat
to let you know how I make out .I hope its just me not seeing something.
Old Apr 17, 2007 | 07:46 PM
  #34
MR NICE's Avatar
MR NICE
Why waste your time and effort on a 305?? Wait till you can do a 350 or bigger
Old Apr 17, 2007 | 10:08 PM
  #35
bogus's Avatar
bogus
Mr Nice,
Take a moment and read her first post. She needs this as a stop gap whilst she rebuilds the 350.
Old Apr 18, 2007 | 09:12 PM
  #36
tiffsc4vett
Well it fits just fine.One of the intake bolts was holding it up.
It was the end of the day and i just wanted to get home.
I want to thamk all of you for the help.This site is a great.
Anyhow i should have the engine in this weekend so I'll let you know how I make out.
Old Apr 18, 2007 | 09:29 PM
  #37
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default intake
Iffff you remember, I mentioned that the front and the back of the block might hit the manifold............ the head intake gaskets will be required to glue two intake manifold gaskets together. I have done it before. It is tricky to get just right. but it fills in the gaps without machining the manifold. If you are only using it for 4 months, what the heck, give it a try
Old Apr 29, 2007 | 08:03 PM
  #38
tiffsc4vett
Well guys its in and running and i do like the 305 its super fast and the low end is sweet.I want to thank you guys for all the help.This is the best place for anyone that has a vett.
Old Apr 29, 2007 | 09:50 PM
  #39
bogus's Avatar
bogus
great!!!!
