Need help with suspension/steering problem
Old Oct 16, 2001 | 05:53 PM
Black1990's Avatar
Black1990
Cruising
Default Need help with suspension/steering problem
I am experiencing very annoying vibration through the steering wheel when going over any rough or uneven road surface. Makes the car a real pain to drive. Also the car seems to wander around and follow the variations in the road. Is this typical symtoms of worn ball joints/tie rod ends etc.?
Black 90
Stock Z51 Coupe
Old Oct 16, 2001 | 08:49 PM
MelloYellow87's Avatar
MelloYellow87
Default Re: Need help with suspension/steering problem (Black1990)
My 87 Coupe does the same and the car only has 42K miles...
Joe D. :confused:
Old Oct 16, 2001 | 08:55 PM
White91's Avatar
White91
I thought that was what driving a fat tired sports car felt like. I've owned a brand new Mustang and now the Vette and have driven many sportsa cars that all did that. Wide tires and stiff suspension don't like road irregularities. Maybe it's time for that sedan?? :D
Old Oct 16, 2001 | 09:22 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers:
I had the same experience with my 88 when I had the GSC tires on
When I switched to the F1 steel, problem went away
Think the tires have a lot to do with it
Jack
Old Oct 17, 2001 | 10:20 AM
GRX's Avatar
GRX
Have you done a front/rear end alignment lately?
[Modified by GRX, 6:21 AM 10/17/2001]
Old Oct 17, 2001 | 03:33 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Need help with suspension/steering problem (GRX)
Mine did that when a front wheel bearing go!
Old Oct 17, 2001 | 03:45 PM
Black1990's Avatar
Black1990
Cruising
I can't believe this could be a normal condition. This is my first Vette but I have driven a 93 Ruby Aniversary with low milage that drove like a dream compared to mine. The shake and vibration through the wheel is real apparent when going over a transition in the road surface like going over a bridge and hitting the front edge where the road changes from blacktop to concrete. What are some of the symtoms you guys have experienced with worn suspension parts?
Old Oct 17, 2001 | 05:20 PM
BrianCunningham
With the bearing it was "directionally unstable".
It tried to hop lanes all the time.
To Need help with suspension/steering problem
