KeyLess Entry
Old Oct 16, 2001 | 11:28 PM
MG-1's Avatar
MG-1
Cruising
Default KeyLess Entry
When I bought my 95 Vette used, it didn't come with a keyless entry remote. I would think that all vettes that year or newer came with automatic door locks/hatch release. If so where can I get a replaement?
Also.. I was pulling into a parking lot one day, and my hatch release popped and hatch came up. THe light on the dash "passive keyless entry" came on and stayed on. THe hatch release kept popping.. I couldn't close the hatch. I pulled the fuse on the hatch and it all stopped. I haven't put the fuse back in yet for safety.
What gives?
Old Oct 17, 2001 | 12:55 AM
TJR's Avatar
TJR
Default Re: KeyLess Entry (MG-1)
Maybe that PKE remote is in the car somewhere? :lol:
Or, the previous owner had similar trouble and just got rid of the remote thinking that would avoid the problem?
Old Oct 17, 2001 | 12:57 AM
tuband's Avatar
tuband
Cruise-In I Veteran
Don't know when keyless entry started but I have it on my '94 and I think it is the same thru '96. Watch eBay as well as the Forum for a buy on a replacement fob (clicker). I picked up a spare on eBay for just over $40.00 and it works great. Dealers charge over $100, I think.
Not sure why your hatch popped and you got the PKE message. It almost sounds like you have a clicker somewhere in the car triggering the locks. Have you checked under & behind the seats?
Old Oct 17, 2001 | 08:38 PM
rcolling's Avatar
rcolling
Default Re: KeyLess Entry (tuband)
I just bought a remote yesterday, $129 at the Dealer, Ouch!
Now I cannot get the car to go into program mode to get the Fob programmed.
Any suggestions that the forum censor will leave alone?
Old Oct 18, 2001 | 12:49 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: KeyLess Entry (rcolling)
Do you have the owners manual? :cheers:
Old Oct 18, 2001 | 01:28 PM
Carroll B's Avatar
Carroll B
The shop manual on my 93 has a good diagnostic for the PKE. When mine acted up I shorted the 2 pins in the diagnostic connector to check for any codes that had been set. There were no codes but it now worked and has been working for the past 20 months.
Old Oct 18, 2001 | 02:31 PM
rcolling's Avatar
rcolling
Default Re: KeyLess Entry (lou sylvestri)
I tried following the instructions in the owners manual, remote comes with the same instructions. At the end when I turn the key off the PKE light is supposed to begin flashing to show it is in program mode. It never does this.
It just stays on solid.
Old Oct 18, 2001 | 02:42 PM
Red Dwarf's Avatar
Red Dwarf
rcolling,
Are you familiar with the info Carroll B mentioned. If you are I can send you some stuff that may help.
Old Oct 18, 2001 | 04:59 PM
rcolling's Avatar
rcolling
Not yet. I have owned this LT4 for less than a week. No Helms manual yet and no familiarity with this car. I have had the 86 for a long time and the manual for it, but that is not a lot of help...
Old Oct 18, 2001 | 07:03 PM
madelko's Avatar
madelko
Just remember, there is a difference between the coupe and convertable Keyless Entry FOB's - Not sure what it is, but they are different.........
[Modified by madelko, 5:06 PM 10/18/2001]
[Modified by madelko, 7:53 PM 10/18/2001]
Old Oct 18, 2001 | 07:10 PM
Red Dwarf's Avatar
Red Dwarf
rcolling,
Sori, but I got you confused with MG-1.(95). Can't help you with an OBD II.... :flag
Old Oct 18, 2001 | 08:27 PM
IndianaJef's Avatar
IndianaJef
I just did the same thing for my 94. I found one from another forum member and got it for 60 bucks - a great deal since the dealer wanted 170.00.
Be sure when you go to program it that you leave it in the house while you get the car into program mode according to the instructions. Then when you bring the keyfob into the car it will lock onto its presence and the PKE light will stop flashing. My keyfob works a much greater distance from the car than they advertised, so maybe that is your problem too. Hope this helps.
To KeyLess Entry
