torque converter DGAF
Old Apr 17, 2007 | 02:50 AM
caesar's Avatar
caesar
5th Gear
Default torque converter DGAF
Hello,
there is a TC signed DGAF. The 'A' means 300# straight rate.
Can this torque converter be used in 1991 C4 ?
Old Apr 17, 2007 | 09:55 AM
conv90's Avatar
conv90
Originally Posted by caesar
Hello,
Caesar, this is the 2nd post you do for Torque converter.
I think it's best you send a PM to Pete K
He can give you the right answer..
-Beppe-
Old Apr 17, 2007 | 10:52 AM
rickneworleansla's Avatar
rickneworleansla
Don't Give A F* ?
I don't know if I would use that one.
Old Apr 17, 2007 | 11:15 PM
Lone Ranger's Avatar
Lone Ranger
P/N on this converter should be B-29L. It is not a carbon fiber lining, it is NON/PWM paper lining. Converter for the Vette application I believe is carbon fiber not paper lining.
D = 1984 and up 700R4, 4L60, 4L60E
G = K factor of 100 or ~ 1400rpm stall
A = ??
F = 3 lug square rear cover
Old Apr 18, 2007 | 02:54 AM
caesar's Avatar
caesar
5th Gear
A = ??
Yes, that's the problem. I've seen a sticker on a stock converter that was signed DGCF. "C" means carbon in transtar's listing.
But converters with carbon are only listed for 4L60E.
Old Apr 18, 2007 | 09:07 AM
BigLee's Avatar
BigLee
i think a paper clutch would be fine for a 91. i dont think the carbon clutched converters for PWM use came along until 95-96?
To torque converter DGAF
