Brights, squirter, AC, Speed control not working?
Old Apr 17, 2007 | 09:50 AM
dhoughton's Avatar
dhoughton
Default Brights, squirter, AC, Speed control not working?
1990 Vette not Z. I was checking to see what was causing these things not to work so I went under dash. I figured these were somehow connected to each other. I found a square plug with four wires not connected to anything. Wires are black, grey, brown and pink with a black line on it. The loose end was down towards the clutch pedal and originates from the dash. I have a photo and can email it to someone if it will help. I looked around for anything it would plug into and could not find anything. Oh my back. I did find a single switch not fully engaged with the top of a pedal and fixed that. The washer pump does work when power is run to it but not from switch in car. Checked all fuses too. Where to go from here?
Fun tracking this down.
Dennis
