chip burners-long crank time with ARAP 6E code solved
Old Oct 17, 2001 | 12:42 AM
drive it's Avatar
drive it
Default chip burners-long crank time with ARAP 6E code solved
I already posted this info at diy-prom, but thought I'd post it here too in case anyone missed it. The 89 code has been noted for long crank times as I'm sure you're aware. In Dec. issue of Corvette Fever the writer of the column "wear and tear" mentioned having the same problem; and a friend of his changed what he thought was a crank rpm vs. injector pulse width. So I e-mailed Tunercat and asked them about it. Within a day they sent me an updated 6E tdf with the table "crank fuel PW multiplier Vs. reference pulse (1-16) I changed 1 to 8 from 0 to .5 and voila!!! NO more %$*&#$%^& long crank times with the 6E code on my 86 without the cold start injector!!! I know this has frustrated me for quite a while and figured I couldn't be the only one goin' up a wall and just had to share!!! :cheers: :cheers:
Old Oct 17, 2001 | 12:58 AM
Hendej's Avatar
Hendej
Default Re: chip burners-long crank time with ARAP 6E code solved (drive it)
Good info! Anything else about 6E code a problem on the '86? Did you just burn 6E into a PROM and go, or was it more involved than that?
Old Oct 17, 2001 | 01:09 AM
drive it's Avatar
drive it
Default Re: chip burners-long crank time with ARAP 6E code solved (Hendej)
Of course I had to adjust the inj. constant and then maf tables a little for my particular combo; but yea, it's pretty much load and go. If you use the arap bin you need to change the fan switch is all to do before starting fine tuning to what you want.
Old Oct 17, 2001 | 02:52 AM
88L98's Avatar
88L98
Cruise-In II Veteran
cool, thanks for the heads up. i have the arap, and i noticed a longer crank time. ill have to take a look at this.
Old Oct 17, 2001 | 05:25 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Glad you were able to get tuner cat to update the ECM config file. I have wanted the location of the acclerator pump table in my EE computer model and all I get from them is 'there are hundreds of parameters in the ECM code....blah blah blah'. Other ECMs config files from tuner cat have the tables defined.
Old Oct 17, 2001 | 11:01 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: chip burners-long crank time with ARAP 6E code solved (AquaMetallic94LT1)
I too have this problem and have Tuner Cat. I do not see the table you identified above. How do you get the update from Tuner Cat? I went to their site, but no luck locating. Thanks for the help and great work!
Old Oct 17, 2001 | 11:26 AM
ZylaRace's Avatar
ZylaRace
Is this the only adjustment you made the missing cold-start injector? I believe there is a temp table that does this also.
Old Oct 17, 2001 | 11:19 PM
drive it's Avatar
drive it
Default Re: chip burners-long crank time with ARAP 6E code solved (ski_dwn_it)
I too have this problem and have Tuner Cat. I do not see the table you identified above. How do you get the update from Tunecat
Just e-mail them and ask for the lastest version "V" Aquametalic-I don't know about the later codes, but for the 8D, 6E, tunercat has been very responsive. Zylarace-I not sure if it effects every combo-but on mine I tried everything possible-with and without the cold start injector and lots and lots of combo's of parameters in the tables-inj. pulse width vs. temp and spark advance cranking vs. temp. This new table is the only thing that did the trick for me!
Old Jul 31, 2004 | 06:57 AM
ben73's Avatar
ben73
Is the fan switch invert option at x0017, bit5?
Old Jul 31, 2004 | 08:42 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
If you check the archieves, which is why I wish we could have some sticky folders, I wrote a tuning article on this exact subject about 1 year ago.
It describes in great detail exactly what I changed and why it works.
Good stuff
Old Jul 31, 2004 | 09:53 PM
scorp508's Avatar
scorp508
The guys (or guy I dunno) at Tunercat are the best! They are always lightning fast to get back to me with any requests I have.
ps.
I have version AJ of $6e right now and that field is in it. What version do you have now?
Old Aug 1, 2004 | 04:10 AM
ben73's Avatar
ben73
ps.
Scorp,
I use Tunercat for my own stuff ('7747), but I am doing this ARAP for a friends 88, so I am using Tunerpro. I have taken care of the cold start issue, just wanna be sure I have inverted the fan outputs correctly. It's a bit difficult because he lives 1000 miles away, so it's not practical to experiment.
I also plan to adjust the ARAP timing table a bit more to mimic the 88's original table as I have read many times that the ARAP bin has quite a bit of timing in it. So basically I'm just creating an ARAP bin for a basically stock 88.
Old Aug 1, 2004 | 08:22 AM
scorp508's Avatar
scorp508
Ok I opened a stock ARAP and changed only the fan & compared the two of them. I got....
d = decimal
h = hex
Code:
Address
            ARAP      ARAP-2      ARAP       ARAP-2
-------   ---(d)---  ---(d)---  ---(h)---  ---(h)---
 00006        91         92         5B         5C
 00007       230          6         E6         06
 00017         8         40         08         28
Old Aug 1, 2004 | 04:17 PM
ben73's Avatar
ben73
Thanks for doing that Scorp!
x0006 and 7 are the checksum, so the fan invert option must be in byte x0017 as suspected.
Thanks again.
Old Aug 1, 2004 | 04:38 PM
scorp508's Avatar
scorp508
Thanks again.
Any time!
To chip burners-long crank time with ARAP 6E code solved
