Really Stupid Question: Long block/short block differences?
What are the primary differences between the long block 350 and the short block 350? I know that the L98 is a short block. What is and isn't compatible between these two engines? What is the physical size difference in size? Can I put a long block in place of my L98?
Basically, if you haven't already guess, I accidentally picked up a long block 350...I'm only out $50 if it doesn't work, but I do want it to.
Please help me in all of my stupidity!
Thanks,
Howie :o
Long Block
Short Block
What is the part number of the long block you purchased. Was it sold
by an on-line vendor? What description did they provide?
ME
within the same block configuration based on reported displacement.
A big block in a C4 would be uhh, a difficult shoe-horn to say the least. I do understand the mains (2 bolt vs. 4 bolt, I know the L98 is a two bolt, and I know that the SB 400 is stronger with the two bolt main). I do know that the motor I bought will have a 2 piece rear main seal.Hmm...lets see what else. I don't need an optispark because I'm going to run the stock intake, and this was out of a pickup.
As far as cams go, I still have some questions...but that bridge is a ways away. Thanks to everyone for all of their help, its been a 'stupid' week for me. I ran into my daily driver with a truck at work...got lost, didn't realize that a longblock just is more complete...one of those few days!!
Basically, here's the plan as it stands right now...I have a 1995 longblock 350 from a pickup. This was a TBI motor, but that really doesn't matter, I don't think, except for the fact that it will be set up to run an HEI distributor, just like the L98. (This is good) I'm going to have the block cleaned up and machined. The cylinder walls will be bored .030" over, and I'm going to use a 400 crank, aka, a 383 stroker. For the top end, I'd like some aluminum cylinder heads, either ported and polished factory heads, possibly some ported and polished aftermarket heads (I like Dart and Brodix, people seem to have a lot of luck with them), but it is all dependent on funds and what is available. I have not selected a cam or what kind of rockers yet. For the intake, I'm thinking I might go with an Accell Super Ram. I'm in the process of installing one on the updated L98 that's in the car now. (When I say in the process of...I mean, my intake and stuff is half put back together). I'm thinking either the Accel controller or maybe a Fast XFI system.
Do you guys think this will work? Basically, I'm 19, I'm mechanically inclined, but I'm not even going to try to pretend that I know the first thing about engine building, but I'm hoping that I can learn as I go. I'm thinking at this point, if the worst mistake I make is buying the wrong engine for $50, I'll take it. I'll keep everyone posted on my progress simply based on the questions I'll be asking!
This is probably going to take a while, because I'm in school, (Like real college, a few hours from home, not a JC, so I have to truck my tools from work to back home everytime I'm doing something to the chevy!) so money, time, and energy are scarce. I have all the drive in the world, but I'll be the first one to admit, that all that drive and $1.25 will get me on the bus!
Last edited by big_how; Apr 20, 2007 at 01:23 AM. Reason: I forgot to answer the question in the quote! Duh!
