Mis-fire when engine compartment heat soaked..
Old Apr 18, 2007 | 07:44 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Mis-fire when engine compartment heat soaked..
If the engine gets hot (230+) in stop and go traffic and at some point it clearws up and I nail it, the engine breaks up at higer RPM's 3000+. I would describe it as a misfire..
This even happens if the engine comes back down to normal temps quickly (which it does) but underhood temps have yet had a chance to vent??!?
Could this be caused by a two of the bolts on the cover plate for the chip on the ECM being stripped (the other two still snug down).. ?!?!
engine specs in sig.. I do my own tuning..
Thanks!
BTW: I posted this in the tune section but maybe this is the better place..
http://forums.corvetteforum.com/show....php?t=1680556
Old Apr 18, 2007 | 11:01 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Id be thinking its the ignition control module on its way out mate, pull it out and have it tested. I dont think the ECM screws will be affecting it.
Old Apr 18, 2007 | 11:27 AM
rick lambert's Avatar
rick lambert
, couple other things, I think your ECM is on the firewall? and they are susceptible to heat, I would fix that just to eliminate it. Another thing you may want to do is ohm your injectors both cold and hot.
Old Apr 18, 2007 | 11:50 AM
sami85L98's Avatar
sami85L98
When i was going to Ft lauderdale FL from atlanta last year in summer time, Ignition module kaboom, b/c way too much heat, car will drive 40 miles before it siezed and than wait till it cools down than again 30-40 miles cool down for few min's i did this probably atleat 4-5 times, finally local mech at truck stop found out ignition module went bad, i finally wait till next and man this after i finished spent 400.
Old Apr 18, 2007 | 12:08 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Be sure and coat the new ICM with the packet of grease that comes with it or your new module will stir-fry itself to death in short order, too.
Old Apr 18, 2007 | 12:17 PM
Casethecorvetteman
Only the side that contacts the heatsink gets the thermal grease though!!
To Mis-fire when engine compartment heat soaked..
