86 Vacuum
Old Apr 18, 2007 | 12:21 PM
Bear86's Avatar
Bear86
Default 86 Vacuum
Where do you check the vacuum on an 86?
Old Apr 18, 2007 | 12:50 PM
JAKE's Avatar
JAKE
On my 86, I took it off the power brake booster.
I installed a plastic connector in the booster that has a small bib, maybe 5/16", that I capped off with a rubber cap bought at AutoZone.
When I want to check the vacuum, I just remove the rubber cap and plug in my gauge.
You can also use one of the plenum bibs on the passenger side of the engine plenum where the vacuum to the fuel pressure regulator is.
Jake
Old Apr 18, 2007 | 01:09 PM
Bear86's Avatar
Bear86
Thanks Larry
To 86 Vacuum
