Replace valve covers on an '88
Old Apr 18, 2007 | 12:44 PM
TerryJ's Avatar
TerryJ
Default Replace valve covers on an '88
Hey everybody,
I just bought some spiffy new aluminum valve covers for my 88 coupe. Before I tear into the task of replacing the stock ones, I was wondering if there were any 'gotcha's' to be aware of. I have replaced covers before on other vehicles, but not on this engine with center bolt covers. I checked with a local shop about doing the job and they quoted my between 7 - 8 hours' labor! This got me to wondering if this is a really huge job or what.
Any input or thoughts would be appreciated!
Old Apr 18, 2007 | 01:01 PM
Aardwolf's Avatar
Aardwolf
It's going to be a big job. I think you will have to remove the runners to get the passenger side off. The EGR has to be removed. The A/C unbolted on the passenger side. There is a heavy bundle of wires on the top of the V/C's that has to be moved and flipped upward. I repainted the stock covers on mine when I changed the intake. If you are going to work on the car a lot you may want to do the coolant bypass, delete the air and EGR systems, notch the A/C bracket to remove the V/C easier, and you'll need new gaskets.
Old Apr 18, 2007 | 01:19 PM
wro87's Avatar
wro87
No big problem! Just some time but not 7-8 hrs! My 16yr old son can get it done in less than an hour now if that tells you anything. the runners DO NOT have to come off. you may have to gently lift the wiring out of the way for the injsctors on both side and the ac compressor and may be the alternator un bolted just look well and take your time. First thing is get you a FSM, then to wash it down and get it cleaned up before you start to unbolt (clean engine! happy engine! can also tell you when things are leaking). When you get to the new vlave covers and gaskets we found it to our advantage to use some 3M weatherstrip cemment and glue them in place on the new covers and some cloths pins to hold them in place while drying. Do this first be for you start to unbolt and they will be ready when you are ready to put them back on. Just take your time
Good luck WRO87
Old Apr 18, 2007 | 06:59 PM
draakarmaul's Avatar
draakarmaul
you have to remove the wiper motor bolts........ but thats about the hardest thing- 7-8 hrs?
Old Apr 18, 2007 | 07:18 PM
madman91's Avatar
madman91
Start by dropping the gas tank....
Old Apr 18, 2007 | 07:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I did mine I had to:
-unplug the injectors & move the harness
-move the alt & PS forward or move the wiper motor
-remove the EGR pipe
-move the A/C compressor & AIR and brackets forward
I can't recall if I had to remove the runners, but maybe. If so this will really add time to the job.
Also, you should blow air along the intake base to avoid getting dirt into the heads as you pull the VCs.
Indeed, for the cost the FSM and a few tools you can save a bundle by doing this job yourself. I really do NOT think it's a 1hr job, not the first time anyhow.
To Replace valve covers on an '88
