4+3 wiring for '85
Old Apr 18, 2007 | 08:25 PM
atotalnincompoop's Avatar
atotalnincompoop
Default 4+3 wiring for '85
there are 4 electrical connections on my 4+3 trans.
one into the trans which is the left in this pic. one into the o/d unit, the right in this pic.
another single wire into the o/d unit which comes from up in the shifter area and the last one which i believe is the speedo connection into the tailshaft.
what i need to know is what colour wires run to each connection. i "accidentally" snipped these wires off a while ago while doing my carb conversion and can't remember what is what. my service manual is absolutely no help.
agent86 sent me a wiring diagram a long time ago, but my crappy computer won't open it.
anyone have any insight
thanks
Old Apr 19, 2007 | 12:35 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default wire diagrams
go to checker or autozone, and buy the cheapie Haynes manual. the wiring diagram is in the back.
I think there's a color code in there for the wires as well as circuit numbers.
geez, don't even buy it. bring a pen and paper...........
Old Apr 19, 2007 | 01:23 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
From front to back of car:
1st gear switch = black/white & lt blue
Reverse gear switch = dk blue & lt green
Overdrive enable = dark green
VSS = yellow & purple
You can wire the switches either way, it doesn't matter.
Old Apr 19, 2007 | 01:28 AM
rodj's Avatar
rodj
Yellow / purple to VSS in tailshaft
Green to O/d solenoid
Lt green / Dk blue to backup light switch
If you have a carb then no need for the 1st gear indicator on side cover , is input for ECM only
Old Apr 19, 2007 | 01:31 AM
rodj's Avatar
rodj
Centralcoaster beat me while I was finding my FSM
Old Apr 19, 2007 | 05:42 AM
atotalnincompoop
thank you very much guys
To 4+3 wiring for '85
