Put the car on the dyno
Old Apr 19, 2007 | 12:10 AM
Simmons-Racing's Avatar
Simmons-Racing
Default Put the car on the dyno
I had my 90 on the Dyno tonight. Dynojet
Results,
Max Power 217.89 at 4,600 rpm
Max Torque 296.45 at 3,500 rpm
The power fell off hard after 5,000 rpm. The Air/Fuel was at 11 to 1
Old Apr 19, 2007 | 12:13 AM
88BlackZ-51's Avatar
88BlackZ-51
Results,
Is this an automatic?
Old Apr 19, 2007 | 12:19 AM
Simmons-Racing
Yes. It has a G.M. Crate engine 330hp, No cats, Quiet Flow mufflers, Cut air box, 1.52 Comp Cams R.R., Stock TPI.
Eric
Old Apr 19, 2007 | 12:47 AM
vader86's Avatar
vader86
Eric
Then you see what a stock TPI does to a 330chp long block.
Old Apr 19, 2007 | 05:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
==263chp.
Old Apr 19, 2007 | 07:13 AM
Simmons-Racing
Is there an easy way to lean it out? Would it make that much difference?
Eric
Old Apr 19, 2007 | 02:19 PM
sami85L98's Avatar
sami85L98
What intake they suggest u for this 330 chp crate motor, must be they declare this with a Carb setup. Does not matter lean or rich, Tpi's dont make power after 4600 rpm.
Old Apr 19, 2007 | 02:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
Doesnt matter much, stock cam doesnt make any power up there anyway.
Old Apr 19, 2007 | 02:50 PM
Aardwolf's Avatar
Aardwolf
Eric
There would be a difference, that is really rich. AFPR or PCMforless?
Old Apr 19, 2007 | 04:07 PM
Slalom4me's Avatar
Slalom4me
It has a G.M. Crate engine 330hp, 1.52 Comp Cams R.R., Stock TPI.
350HO #12486041
Specs: 330HP @ 5000 RPM, 380TQ @ 3800 RPM
Camshaft #24502476: 0.435”/0.460”, 212°/222° @ 0.050
Heads #12558060: Vortec Iron 64cc w/ 9.0:1
Are the Vortec heads still on it? If so, what intake base did you
use to adapt the TPI Plenum and runners to the Vortec heads?
The Vortecs breath respectably. With iron heads, 9:1 is compatible
with readily available fuel. My vote is that you are closer to realizing
the engine's potential than it might have first seemed.
Old Apr 19, 2007 | 04:35 PM
Danspeed1's Avatar
Danspeed1
I'm not quite up to the heads and cam yet, but I know there has to be a way to make the TPI perform higher then 4600... The second most popular conversion after LS1 is TPI....
DG
Old Apr 19, 2007 | 04:45 PM
hippy's Avatar
hippy
DG
You are correct there is a way. It's called ditch the TPI and put a SR or MR on.
Old Apr 19, 2007 | 04:55 PM
Danspeed1's Avatar
Danspeed1
But
I
Like the TPI
Old Apr 19, 2007 | 05:31 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Then heads and cam it is!
Old Apr 19, 2007 | 07:23 PM
JAKE's Avatar
JAKE
First, you need to understand that the TPI was originally designed for the 305 (Three-0-Five) cubic inch engines.
So, then GM plopped it on a 350 (three FIVE O), which is 45 cubic inches larger. Think of it this way, if your 350 had 45 more cubic inches, it would be a 395!! Add 45 cubic inches to that and you'll have a 440!!!
So you can see from the get-go that airflow is going to be your main problem; a 305 system trying to feed a 350 engine.
Ever wonder why the SuperRam, Holley Stealth Ram and TPIS' Mini-Ram are so popular. Yep; you've got it.
Get an intake setup that'll breathe above 4500 RPMs and, THEN you'll be good-to-go.
Jake
Old Apr 19, 2007 | 07:58 PM
Simmons-Racing
Yes they are using a carb setup.
Old Apr 19, 2007 | 08:00 PM
Simmons-Racing
Originally Posted by Slalom4me
350HO #12486041
No the Vortec heads are not on it. Someone put the 113 heads back on.
To Put the car on the dyno
Old Apr 19, 2007 | 08:16 PM
sami85L98's Avatar
sami85L98
Here is my Dyno graph of my old 350 motor with Tpis flat tappet Cam/Dart heads, headers,........and Accel manifold, Tpis ported plenum, and Accel LT runners, this is my old combo, my current one is 383/219/dart heads/SR..... here is a dyno graph of old TPI
Observe no power after 4700 rpm, even this Tpi is aftermarket with LT runners, accel base and ported plenum.
Old Apr 19, 2007 | 08:23 PM
cdnguyred88's Avatar
cdnguyred88
My next mod is an intake or gears.
Old Apr 19, 2007 | 11:05 PM
hippy's Avatar
hippy
Then heads and cam it should be. Waste some good money on heads and cam then put a TPI on it and watch the HP STAY THE SAME as if you had the stock heads and cam on it.
Lets play pretend.
You are in the middle of an open field no one around you and all the fresh air you can breathe. Put a 1/16" dia straw in your mouth and see how much air you can suck in in 1 minute. Now lets pretend that the straw is a TPI intake.
Danspeed, keep your TPI if you like it so much. You will be limited to around 280 rwhp with an automatic car. If that's enough you don't need a MR, SR, aftermarket heads or aftermarket cam.
