Opti Spark harness question???
Old Apr 19, 2007 | 07:53 AM
LPDesRoche's Avatar
LPDesRoche
Default Opti Spark harness question???
When updating from the early style to the 95 and later opti do you just use the newer style harness to attach the opti or is there some pinouts that need to be swapped around? I used to have a link to a page that had all the info on the swap but have since lost it. Any help is appreciated.
Old Apr 19, 2007 | 08:03 AM
Tom Piper's Avatar
Tom Piper
The '92 has different connectors for the Opti-Spark under the right fuel-injector cover.
So, for the '92, you can use the new '95 style Opti harness if you change the connector under the fuel injector cover.
For a '93 and '94, I think you can buy the new '95 style harness and plug it in.
Tom Piper
Old Apr 19, 2007 | 08:28 AM
LPDesRoche's Avatar
LPDesRoche
That's kind of what I remembered, just wanted to confirm before I ordered it. Thanks Tom
Old Apr 19, 2007 | 12:22 PM
STL94LT1's Avatar
STL94LT1
On my 94 I had to trim part of the connector to get it to connect. Once you get the new harness, it will be pretty obvious. No repinning was needed.
Old Apr 19, 2007 | 01:43 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
You know you can buy a 92-94 opti already vented from MSD.
Old Apr 19, 2007 | 01:56 PM
Tom Piper's Avatar
Tom Piper
....and, I believe Dynaspark too.
Tom Piper
To Opti Spark harness question???
