Does anyone have a diagram of how this thing goes in? I have two different ones, and one looks pretty simple, but the other looks very complicated. Is it just a typical install with the bearing going into the fork and resting on the pivot ball (the fork i mean)? Is there a part i'm missing? i have a 6 speed! Was there a 5 speed in this car for this year? The lady at the parts counter at chevy said there was, but i don't know enough about them. Thanks!!
I know this doesnt answer your question, but....
Im assuming you are doing a clutch change. If so, heed my advice.
You may be better off re-using your OEM throwout bearing.
ACDelco has contracted these out to CHINA and the new ones are much sloppier (wobbling in its sleeve) and more prone to breakage than the ones that GM installed in our car.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
At the very least, inspect the thin flange on the t/o bearing for cracks from manufacture.
