1985 speedometer/speed sensor problem HELP
Old Apr 19, 2007 | 06:57 PM
masterprice33's Avatar
masterprice33
Default 1985 speedometer/speed sensor problem HELP
My '85 has a speedometer/speed sensor issue. Speedometer works fine when I drive the car around for the first 10-15 min of driving in cold condition. Then I'll look back at it and it's fluctuating then eventually goes and stays at 0 not long after. I'll park the car for an hour and the speedometer will still be at 0. But every time I park it for the night and drive it much later, like in the morning, speedometer is back to working fine. I'm quite positive it is the speed sensor, but what I want to know is what the malfunction is? Is the sensor losing voltage under hot conditions? I'm not a knowledgeable corvette guy, so I'll need some opinions or answers. If it helps, I had the computer replaced recently so I figure I could rule out the connection to the ECM, as this problem was apparent long before.
Old Apr 26, 2007 | 01:18 AM
drive it's Avatar
drive it
The sensor input goes to the dash then the ecm. If you scan it and the ecm is reading mph correctly and the dash says zero I would suspect the dash cluster.
