No cruise control
Old Apr 20, 2007 | 10:01 PM
indasouth's Avatar
indasouth
8th Gear
Default No cruise control
Anyone know much about cruise? Mine doesn't work. I've got a 1994 Corvette. The fuse is good and the vaccuum seems good. Any suggestions would be appreciated.
Old Apr 21, 2007 | 12:53 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default cruise
edited for content
Old Apr 21, 2007 | 12:55 AM
Scott-89's Avatar
Scott-89
I need to do this as well. My cruise control will work for awhile but then it dies.
Old Apr 21, 2007 | 08:54 AM
indasouth's Avatar
indasouth
8th Gear
vaccuum seems good. I hope it's not a control module.
Old Apr 21, 2007 | 09:10 AM
jimmers's Avatar
jimmers
Check to make sure its plugged in under the dash. If you have a 6 speed there should be a connector at the clutch and brake.
Old Apr 21, 2007 | 09:20 AM
lone73's Avatar
lone73
Check here...
http://www.corvetteactioncenter.com/...ad.php?t=87507
and here...
http://www.corvetteactioncenter.com/...ad.php?t=93292
good luck
Old Apr 22, 2007 | 11:34 PM
indasouth's Avatar
indasouth
8th Gear
Definitely have a vaccuum problem. Now that the weather has warmed up I cranked up the a/c and it quits blowing out the vents when I accelerate. I'll have to check for leaks again.
Old Apr 23, 2007 | 12:25 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Yep,thats the sign of a bad check valve and vac leak.
It happens when you accelerate.Replace the check valve first and see if it fixes it.Its cheap and few minute job.
Old Apr 23, 2007 | 10:35 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Originally Posted by coupeguy2001
check all of the vacuum lines. There is a vacuum check valve near the left hand rear of the engine and check the bottom of it for cracks, warped or missing plastic.
Yep, it's under the fuel rail cover.
Old Apr 23, 2007 | 02:20 PM
Bigwhite88's Avatar
Bigwhite88
Default check valve
Does this location work for 88's also. I have a vacuum line hanging loose from cruise sevo and another from vac tank, but nothing else in the area that looks like a source.
Old Apr 26, 2007 | 09:55 PM
indasouth's Avatar
indasouth
8th Gear
BINGO!! $5.oo part under the fuel rail was the culprit. Thanks for the help.
To No cruise control
