A really basic question... brake bleeding
Old Apr 22, 2007 | 04:18 PM
qwiketz's Avatar
qwiketz
Default A really basic question... brake bleeding
does the car need to be on? I bled my brakes and got some fluid out, but not as much as I would have imagined. Does the car need to be running? I did all 4 corners and got about 12-16 oz of fluid out of the system. I was trying to go more toward flush since it hasn't been done in a while.
Old Apr 22, 2007 | 04:23 PM
STL94LT1's Avatar
STL94LT1
No, the car doesn't need to be running to bleed the brakes.
Old Apr 22, 2007 | 04:51 PM
John A. Marker's Avatar
John A. Marker
I usually buy a clear flexable plastic tube and place this tightly over the bleeder and insert the tube into a clear glass jar with a small amount of fluid in the jar. This way when you pump the brake you can see any air bleed out and also the color of the fluid. Just keep adding fluid to the reservoir as you pump the breaks until you get clear fluid through the tube. Using the tube also stops air from being sucked back into the lines.
Old Apr 22, 2007 | 06:29 PM
STL94LT1's Avatar
STL94LT1
Also, from what I remember ~16 oz will pretty well bleed the system.
Old Apr 22, 2007 | 10:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I prefer to have the engine running so there is vacuum present for the brake booster.
Old Apr 22, 2007 | 10:42 PM
qwiketz's Avatar
qwiketz
Also, I have brembos on the front so there's two bleeders. I can bleed them one at a time right? I don't have to bleed them at the same time right?
Old Apr 23, 2007 | 08:31 AM
Doctor Mark's Avatar
Doctor Mark
1 at a time. Outboard bleeder first. Not necessary to have the car running.
Old May 2, 2007 | 03:07 AM
qwiketz's Avatar
qwiketz
great.... I took apart the master to install the drm spring. After putting it back together I bled the brakes and now the darn pedal goes to the floor with th car off. I obviously did something wrong. Time to take it apart and try again.
Old May 2, 2007 | 04:28 AM
John A. Marker
Try this, there should be two lines running out of the MC. Screw in brass fittings (that have a long section to slip tube onto) into the MC where your normal brake lines would go. I believe there are two different sizes, not 100% sure on your car. They make a MC bleeding kit that has plastic fittings that may be less expensive. Then take tubing and run from these fittings and loop back into the MC. Add brake fluid. Have some one pump the brakes several times as you hold the tubes in place. This forces the brake fluid from the MC into the tubing and will bleed out any air in the MC itself. When you no longer get any air thru the tubing disconnect the fittings and connect the brake lines. Now bleed the brake lines.
Suggest you use the clear tube and jar with fluid as I mentioned in earlier post.
Good Luck.
Old May 2, 2007 | 07:19 AM
runner140*'s Avatar
runner140*
Your method has worked for me for years.
Old May 2, 2007 | 07:55 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
Default Master cyl fittings size
On the master the front fitting size is the same as a stock caliper bleed screw ( I have J55's & the bleed screws fit the front master port), and the rear fitting is the same size as the bleeder from a zf6spd slave cylinder.
Don't know if that helps.
Tom
Old May 2, 2007 | 08:00 AM
jmrl98's Avatar
jmrl98
Any of your local auto parts stores have the one-man bleed system - around $6. Works great. It has adapters for different size bleeders, lengths of tubing, and a see-through plastic bottle.
Old Jun 24, 2007 | 03:03 PM
davidnclearlaketx's Avatar
davidnclearlaketx
Default Will MC bleed be enough?
I don't have access to a floor jack right now and I was wondering if I just bleed the MC on the bench and then install it, would the brakes be good enough so I could make it a couple of miles down the road to my friends shop who has a lift so then I could bleed all 4 wheels?
Anyone ever just bleed the MC and that's all that's needed?
Wishful thinking I know!
Thanks for the help in advance!
Old Jun 24, 2007 | 03:49 PM
creoleman's Avatar
creoleman
David, that just doesn't sound like it would be safe. Please don't take chances where brakes are concerned. Good luck. the Creoleman
Old Jun 24, 2007 | 05:36 PM
Keystring's Avatar
Keystring
Yes you can bleed the MC on the bench and then install it.
PROVIDED you didn't disconnect the brake lines from any place other than the MC. When you disconnect the lines from the MC very little fluid is lost from the lines.
Once the MC is bled, reinstall it and tighten the lines down finger tight.
Have someone push the pedal down until you see fluid coming out of the loose lines.Both lines should show fluid flowing.If they don't then loosen them up a little until they do. This will refill the lines and allow any air to escape. While your friend is holding the pedal down, tighten both lines.
I've done it this way many times without having to bleed the whole system.
Old Jun 24, 2007 | 05:41 PM
Aardwolf's Avatar
Aardwolf
I would drive it after testing it in the driveway first. If you leave the lines cracked at the M/C and have someone slowly press the brake while fluid and air seeps out, then close the lines before the pedal gets to the floor, there should be very little if any air.
Old Jun 25, 2007 | 12:28 AM
davidnclearlaketx
Thanks guys!
I'll give it a shot and then down the block during NON rush hour traffic!
To A really basic question... brake bleeding
Old Jun 25, 2007 | 07:39 AM
Da Mail Man's Avatar
Da Mail Man
Good Luck.
... that's how i do it!
Old Jun 25, 2007 | 07:44 AM
Da Mail Man
.... ......the manual states that if you disconnect any line at THE WHEEL then you can get away with bleeding just that line. HOWEVER, if you disconnect the lines at THE MC, you MUST bleed the entire system!
Old Jun 25, 2007 | 09:07 AM
Aardwolf's Avatar
Aardwolf
There are more and better ways then the manual though.
