** Help with tire size question **
Old Apr 22, 2007 | 10:05 PM
Ricks95's Avatar
Ricks95
Cruising
Default ** Help with tire size question **
I have a question in regards to tire size on a 95 coupe. Currently it has the 17x8.5 frt and 17x9.5 rear. I will be changing over to all 17x9.5 at all 4 corners and was wondering on tire size. I know that the z07 option in 94 had all 4 tires at 17x9.5 with 275/40/17. I was wondering if I could stick with 285/40/17 at all for corners or should I go with the 275/40/17 instead. Main issue would be tire rub on the front since the rear currently is running 285/40/17. Thanks in advance.
Rick
Old Apr 22, 2007 | 10:13 PM
aminnich's Avatar
aminnich
I am running 285/40s on the front, 315/35s on the back. No Problems.
(on 9.5 and 11 rims of course).
Old Apr 22, 2007 | 10:22 PM
Ricks95's Avatar
Ricks95
Cruising
Do you have a ZR1 or the LT1.
Old Apr 23, 2007 | 12:56 AM
KCHOTBOAT's Avatar
KCHOTBOAT
Running the same setup on a lowered car. I may be going to 17x11 up front with 315's for autox.
Old Apr 23, 2007 | 07:58 AM
aminnich's Avatar
aminnich
LT1. (Look at my avatar picture)
Old Apr 23, 2007 | 08:04 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The 285's are only a slight bit wider. A lot of us have 275's on the front and how often do any of us go to full lock?
To ** Help with tire size question **
