Coolant flush
Old Apr 23, 2007 | 02:20 PM
78pacer's Avatar
78pacer
Default Coolant flush
What are the procedures for flushing\changing out the coolant on a 95 LTI. Any help would be appreciated.
Mike
Old Apr 23, 2007 | 02:27 PM
Fast Cop's Avatar
Fast Cop
The FSM for my 96 calls for the knock sensors to be removed for a full flush from the block, but that is a royal PITA. Based on my experiences and from what I have read on this forum the best was is to drain from the radaitor, fill, run up to temp and repeat. (wait for cool down prior to the repeat). If you do this about 3 - 4 times you should have a fairly clear water upon last drain. On your last refill use the proper 50/50 mix.
Old Apr 23, 2007 | 03:00 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Instead of removing the knock sensors, I'd do what Fast Cop suggests, then reverse-thrust a 6.5 hp or higher Shop Vac to blow the coolant through the engine block, heater core and out of the radiator pitcock.
Just unscrew the metal pressure cap and put the hose over the coolant tank refill hole (black plastic tank) on the passenger side of the engine. The forced air will do the rest.
Next, refill with water, then blow it all out again with the Shop Vac until you're satisfied nothing remains in the system.
Then, refill with coolant/water mix, and open the bleed valve screws as outlined in the FSM or owner's manual to burp the system of trapped air pockets.
Old Apr 23, 2007 | 05:15 PM
78pacer's Avatar
78pacer
Very cool indeed. I wonder if I can do the same with my garage air compressor at low psi? Furthermore, where are the bleed valves located?
Mike
Old Apr 23, 2007 | 09:33 PM
78pacer's Avatar
78pacer
ttt
Old Apr 23, 2007 | 10:18 PM
Hotred94's Avatar
Hotred94
I have an electric water pump and a T fitting in my heater hose. I just hook on garden hose, open rad drain, and turn on water pump to circulate flush throughout the engine (no need to turn on engine with electric).
The bleed valve (if it is like a 94) in on the neck of the upper water pump intake. It's a small brass screw. Make sure you don't leak coolant onto your opti while bleeding; use a big rag to wrap around everything.
Old Apr 24, 2007 | 06:22 AM
78pacer's Avatar
78pacer
Thanks for the replies. Back to Prestone for me!
Mike
Old Apr 24, 2007 | 09:30 AM
onedef92's Avatar
onedef92
Mike
The reason I said Shop Vac is because the diameter of its hose is very close to the diameter of the coolant refill tank opening.
You want a tight seal in order to ensure the forced air will fill all the water galleys and passageways throughout the engine and coolant system.
Old Apr 24, 2007 | 11:18 AM
Strick's Avatar
Strick
Because I do this so infrequently I wanted to really flush the entire system. This is how I do it. I'm into over kill.
https://www.corvetteforum.com/techti...=222&TopicID=2
I, too, have an electric coolant pump and it makes it so easy to fill the system as you don't have to do the ole "burp" procedure.
Old Apr 24, 2007 | 11:19 AM
rickneworleansla's Avatar
rickneworleansla
Do you have any pictures of the T-fitting? What type was used? I just ordered my Meziere last week.
Old Apr 24, 2007 | 11:40 AM
onedef92's Avatar
onedef92
Make sure you don't overtighten the brass bleed screw, either. It's easy to deform the head of the screw since brass is a soft material.
Old Apr 24, 2007 | 02:46 PM
69mako's Avatar
69mako
Remember to catch all your old coolant and bring it to a local shop or garage to dump it there. Its nasty stuff and you really don't want that going into the water enviroment
I use two 5 gallon donut buckets I got from my local Dunkin Donuts to catch all my flushing, makes it as easy as pie, all I do is set one under the rad petcock and flush away plus I don't have all the slick coolant on my garage floor.
The cool thing about the buckets is that they are very sturdy with a snap lid that has an O-ring...no messy fluid sloshes out
To Coolant flush
