Tweaking Fuel Pressure Regulator
Old Apr 27, 2007 | 12:08 AM
Dads90's Avatar
Dads90
Default Tweaking Fuel Pressure Regulator
What would happen if I put a quarter under the cap of my FPR. The pressure is slightly lower than spec (35 PSI ) and I don't want spent 90 bucks for a adjustable right now. Would it help, hurt, not make a differance ?
Old Apr 27, 2007 | 12:15 AM
Siveck's Avatar
Siveck
It would be alot of work and gaskets for trial and error sessions.
Old Apr 27, 2007 | 12:19 AM
Dads90's Avatar
Dads90
Well I've presently have the fuel rail off and its setting on my work bench. Now if it doesn't work, It will we work to remove the plenum and redo it.
Old Apr 27, 2007 | 12:58 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default fpr
try stretching the spring slightly in the fpr, not a lot, just a little
Old May 9, 2007 | 11:16 AM
Cmanhome's Avatar
Cmanhome
I read where you can pull the vacuum hose off the regulator and block the end of the vacuum line and also
plug the hole where the hose came off and this will increase the presure to it's full potential. This was a tweak from things to increase horse power.
Hope this helps and it is easy to do.
Old May 9, 2007 | 04:49 PM
tequilaboy's Avatar
tequilaboy
I used a nickel under the lid and got 54 psi (it was originally 46 psi) in mine (88).
At 35 psi, it may be time for a new diaphragm and spring.
To Tweaking Fuel Pressure Regulator
