-92 Trans Fluid Check Sequence
Old Apr 27, 2007 | 12:58 PM
Arcezzu's Avatar
Arcezzu
Cruising
Default -92 Trans Fluid Check Sequence
Hello there!
I have a -92 LT1 which I noticed today leaks a couple of drops of red trans fluid when car has been driven hard.
I have checked the car often but this day I tested the performance a little more and noticed this.
I know there is a sequence for checking the Trans Fluid level, to get proper values.. Like starting the car, changing gear to Park-Mode and so on - and last pull the Trans Fluid dipstick.
Is there anyone who can tell me this sequence?
Thanks alot!
Old Apr 27, 2007 | 01:16 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Well that's a first for me. I always knew it as checking the AT fluid when the fluid was warm, motor running and on level ground.
Eric
Old Apr 28, 2007 | 09:07 AM
Arcezzu's Avatar
Arcezzu
Cruising
Hello Howser, thanks for the fast reply. You mean that there is no sequence needed except engine and fluid being hot when performing the test? Thanks..
To -92 Trans Fluid Check Sequence
