new wires and plugs
Old Apr 28, 2007 | 10:52 AM
VetteMan1989's Avatar
VetteMan1989
Default new wires and plugs
Thinking about replacing wires and plugs, running ruff. Should I go with OEM products or is there something better to make my vette run like new?
Old Apr 28, 2007 | 12:22 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
MSD 8.5 wires, ACDelco Rapidfire plugs, but thats not all that will be required to run like new... Time, cap, IAC, TPS, air, FP, Injectors, all are part of the puzzle...
Maybe more info on how its running and whats going on will help diag the problem.
and you only need 1 post to get your questions answered.....
Old Apr 29, 2007 | 03:38 PM
VetteMan1989
thanks, I will work on getting all those parts replaced and then we will see how it runs
Old Apr 29, 2007 | 04:16 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you want wires to fit the stock looms and look essentially stock, try the TPIS wire set.
Get stock A/C Delco spark plugs, cut back the ground electrodes (on my site) and set the stock gap.
As for "run like new", hmmmm....
To new wires and plugs
