Speedometer calibration
Old Apr 28, 2007 | 04:55 PM
jd86L98's Avatar
jd86L98
Default Speedometer calibration
Has anyone used the speedometer gear calibrator from zip products? Seems to good to be true.
Old Apr 29, 2007 | 04:12 AM
xrcrx's Avatar
xrcrx
I have it in my 84. Changed from 3.07 to 3.75 gears. It's dead on. Uses dip switches to adjust the output from the trans to speedo. Instructions are easy and so was installation. Best part is, if ya change gears again you just reset the switches again. A lot easier than changing the gears in the trans etc.... IMHO
Old Apr 29, 2007 | 02:32 PM
tequilaboy's Avatar
tequilaboy
There are some much cheaper options available including standard vss drive and driven gears.
For a calibrator, I like the Dakota Digital SGI-5. I have an older version (revision A) with dip switches that works fine. I think the newer models use buttons for programming the correction factor.
http://www.dakotadigital.com/index.c...rod/prd126.htm
Old Apr 29, 2007 | 07:13 PM
CFI-EFI's Avatar
CFI-EFI
The calibrator is a good way to go if you have money to burn or a troublesome ratio change to match up to. Otherwise, stock Chevy gears will usually do the job for 10.00 to $30.00.
RACE ON!!!
Old Apr 30, 2007 | 12:06 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
RACE ON!!!
The speedo gears are not hard to change either.
Old Apr 30, 2007 | 07:42 PM
Phil Ferency's Avatar
Phil Ferency
I have the gizmo from Zip on my 92 6 sp with 4:10 gears. Works great. Biggest problem was the wire install on the trans with my fat fingers.
To Speedometer calibration
