Dyno Numbers
Old Apr 29, 2007 | 03:12 PM
JAKE's Avatar
JAKE
Default Dyno Numbers
Here's a link to a site with some dyno numbers for L98, LT1 and carbed SB engines.
Just in case you haven't seen them before.
http://www.geocities.com/MotorCity/7610/dyno.htm
What surprised me was that a LT1 block can take a .100 over-bore!
Jake
Old Apr 29, 2007 | 03:14 PM
88BlackZ-51's Avatar
88BlackZ-51
Yeah. That's an old link.
Old Apr 29, 2007 | 04:20 PM
JAKE's Avatar
JAKE
I'm sure it is, but there are a lot of new members who may not have seen it. Lots of folks haven't been around as long as you and me.
Jake
Old Apr 29, 2007 | 04:50 PM
5abivt's Avatar
5abivt
Probably the only lt1 gone .100 over. god knows what kind of issues that motor may have had from it.
Old Apr 29, 2007 | 04:54 PM
LAAllison's Avatar
LAAllison
Default Dyno info
Thanks Jake. Good info. The Traco looks like an easy way in to a nice street package for my 89.
Art
Roll Tide
Old Apr 29, 2007 | 05:19 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Jake
I've been around awhile and I hadn't seen it. That'd be some good info for anyone planning a build to ponder. And it's just an interesting set of combos to look over for any of us interested in such matters. Thanks.
Old Apr 30, 2007 | 03:48 PM
JAKE's Avatar
JAKE
I agree. My thinking was always that +.040 was about the limit on a SB, while BBs can usually take +.060 safely; USUALLY, not always.
I had a Bb bored .060 and when I was washing it prior to assemble, I found one of the bores had a long crack in it down near the main web area.
It was in a spot that even a sleeve wouldn't help, so that block became a over-sized paper weight.
At .100 over, I bet the walls were vibrating like crazy.
Jake
Old Apr 30, 2007 | 04:09 PM
SJW's Avatar
SJW
Most interesting. Thanks for posting this. I hadn't seen it before, either.
Be well,
SJW
Old Apr 30, 2007 | 04:19 PM
edcmat-l1's Avatar
edcmat-l1
Jake
Didnt read it. Did they happen to say whether it was sonic checked? And what the cylinder wall thickness was afterwards. To do a .100 over SAFELY, the walls would need to be .300 to begin with. Dont see that bein the case.....
BTW, we've done several .125 over big blocks. Back in the day, before all the aftermarket blocks, thats what ya had to do to build a big motor.
Done a couple BB fords .125-.140 over. Poked and stroked 460s up to 514 with offset ground cranks.
To Dyno Numbers
