Fast Enough?
Old Oct 18, 2001 | 08:58 PM
vette4kjl's Avatar
vette4kjl
Default Fast Enough?
I have a '94 LT1, 6spd, with the stock 3:45 ring & pinion. My goal is to be able to beat a stock Viper GTS. Here is the list of modifications that I have done:
SLP cold air intake, throttle body air foil, MSD 6AL ignition, CORSA cat-back exhaust, Edelbrock Peformer IAS shocks, adjustable fuel pressure regulator(set at 47psi), Hypertech power programmer III(used for turning on cooling fans earlier), NOS(150hp), AFS wheels(17X9 1/2 w/Dunlop SP8000 275/40/ZR17's front, 17X11 w/Dunlop SP8000 315/35/ZR17's rear), Venom 400 throttle enhancer, and Autolite spark plugs.
My question is whether or not I will be able to attain my goal of beating a stock Viper GTS with these modifications? Thanks in advance!! :chevy
Old Oct 18, 2001 | 09:33 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: Fast Enough? (vette4kjl)
No. Heads, cam and bigger motor are needed. You probably have 320 hp. Viper has 450 so you are a bit short. Now 150 HP of nitrous would get you there.
Old Oct 18, 2001 | 09:39 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Fast Enough? (AquaMetallic94LT1)
re-read his post.. he's got the 150 shot of NOS...
Should be able with the click.
ANTI VENOM's Avatar
ANTI VENOM
It looks like he already has nitrous. With that set up I would not hesitate to race a stock viper GTS. A good driver could win that race or at least make that viper nervous for awhile.. Have fun and try to be safe!! :smash:
To Fast Enough?
