Torque Wrench Question
May 1, 2007 | 02:25 PM
The instructions are telling me to torque a bolt to 180 inch lbs?
However, I only have a torque wrench measured in foot lbs.
Can any tell me how to convert the 180 inch lbs into foot lbs?
Thanks in advance.
May 1, 2007 | 02:36 PM
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Divide by 12 = 15 ftlbs. (12inches in a foot)
May 1, 2007 | 02:40 PM
Quote:
Originally Posted by
PDQUIK95
Thank you
I wasn't sure it would be that simple.
May 1, 2007 | 08:55 PM
PDQUIK95
May 1, 2007 | 10:36 PM
May 1, 2007 | 11:56 PM
2021 C6 of the Year Winner - Unmodified
86 Red Neck
Gee, thanks I was looking for a conversion chart like that some time back.
May 2, 2007 | 01:40 PM
I am looking to get a torque wrench.
Is it better to get a 3/8 or 1/2 inch wrench?
May 2, 2007 | 01:59 PM
9vette4
Depends on the sockets you have and the range of torques you need.
There are only a few places on a car where you really need precise torque (head bolts, spindle nuts, etc.), and 1/2" is more appropriate for those.
Most torque specifications on a car are there simply to keep simians from overtightening things.
May 2, 2007 | 02:00 PM
May 2, 2007 | 02:24 PM
If you get a 1/2 inch torque wrench don't try and use it in the low range (where you are in inch/lb territory) the ones I've used are completely inaccurate in that range.
May 2, 2007 | 05:19 PM
I have two 1/2" torque wrenches (150ft lb and 250 ft lb), a 3/8" (inch lb scale). I bought the bigger 250 ft lb wrench when I did the brakes (something had a torque spec of 175 ft lb If I remember correctly).
