window ribbon...dumb question
Old May 4, 2007 | 11:59 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
When mine broke I used the old broken pieces as a guide to cut to length as well.No problems at all.
I can see where you said someone had replaced the ribbon before...alot of people will use screws/nuts instead of pop rivets GM loves to use.
Btw,These ribbons were very popular on Dodge minivans and etc.I knew a guy who replaced his ribbon 4 times in 8 years on the same window.
They just dont last very long.Use aloot of good grease and it should be good to go for a little while.This guy used his van everyday,put 300K on it so thats probably why his replacements didnt last too long.
Old May 5, 2007 | 12:50 PM
okinawa86vette's Avatar
okinawa86vette
Yeah, that's the ribbon I picked up, listed for a dodge.
As long as it lasts 6 months or more, I'll be happy. I'm just fixing this car up to sell, so the next owners can upgrade if they want.
When I first tore into the door, I didn't see the piece that had broke off, so I was a little concerned with figuring out the proper length, but the piece was down there, so no problem. I cleaned the track and used plenty of white lithium grease.
It wasn't a hard project at all. I would sugest anyone do it themself before forking over probably 3 or 4 hours of labor to have someone else do it.
Chris
