Dual Fan kit
Old May 1, 2007 | 08:37 PM
86malcomekonnner's Avatar
86malcomekonnner
Default Dual Fan kit
Has anyone tried the dual fan kit from Mid America? if so please share the details
Old May 1, 2007 | 11:52 PM
bogus's Avatar
bogus
they are expensive... I would get the heavyduty conversion and be done with it.
Old May 2, 2007 | 12:01 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Most people will never even max out the stock fan enough to bring the auxiliary front fan on. If the stock fan isn't keeping up the your cooling system is probably not up to snuff.
What are you doing with the car?
Old May 2, 2007 | 07:39 AM
86malcomekonnner
The car has a 355...Im just about to start the MiniRamII conversion..I plan on puttin a t3/t4 turbo on it in the somewhat near future as long as everything goes well. I'm also going to be wiring in a megasquirt Spectrum. Now i know that i'll be able to set the fan temp with the M/S but I have a problem keeping it cool at idle. It has a 160* with the 165 fan switch right now.
Old May 2, 2007 | 07:48 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
So once you warm up the fan runs all the time and it still gets hot? How cool is "cool at idle"?
Old May 2, 2007 | 08:48 PM
86malcomekonnner
usually i dont sit long enough to get above 190 but if i take a good highway ride and sit at a light just after ill see it hit 200+
Old May 2, 2007 | 09:08 PM
bogus's Avatar
bogus
don't worry. any cooler and the metals will stop expanding at the accepted rates.
figure that the fans don't normally come on until 228 or so... you are a-ok.
A turbo? you will want a bigger rad anyway. and an intercooler.
Oh, and a 355 is simply a 350 bored .030 over. It's essentially a stock rebuild. I hope that the engine internals were upgraded to deal with turbo boost.
Old May 2, 2007 | 10:10 PM
CentralCoaster
What are your current fan settings? Stock?
As bogus said, you can't blame the fan for the car getting up to 228, because the fan doesn't even come on until then.
If you don't like those temps for some reason you can program the fan settings or use an override switch to force the fan on earlier.
If the fan is running and can't pull the temp down, then you have a problem.
Old May 3, 2007 | 07:53 AM
86malcomekonnner
the fan is set to come on at 165...and yes the compression has been lowered to 8.5:1 to compensate for boost. The bottom end is good to go..now i'm just working on the top end
To Dual Fan kit
