Main Cat Question
Old May 1, 2007 | 10:00 PM
B-906S's Avatar
B-906S
Default Main Cat Question
On my main cat there is a tube that goes up by the header what is this? I would like to know because i want to replace it with a straight pipe. Thanks
Old May 1, 2007 | 10:04 PM
bogus's Avatar
bogus
it's part of the AIR system. disconnecting it only slows the cats light off time.
Where do you live? removing the cat is a $10k federal fine... and you will never pass the sniff again.
I am a big fan of removing the entire L98 exhaust and installing a dual system using bullet cats and an xpipe.
Old May 1, 2007 | 11:38 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It connects to a check valve beside the passenger side exhaust manifold. The smog pump pumps air to the cat through this line. If the line is left open it'll make some noise, although it probably won't be audible if it still terminates under the car.
Old May 2, 2007 | 02:42 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
It helps warm up the cat for optimal use.
Mine has all been disconnected when I gutted the cat and removed the AIR system. The line is still attached to the cat housing, but it doesnt do anything. I am too lazy to cut it all the way off heh.
Old May 2, 2007 | 03:46 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Replace it with a high flow cat with an air tube and reconnect it.
It would help if you would fill out your profile.
Old May 2, 2007 | 05:57 PM
B-906S's Avatar
B-906S
I live in missouri and i dont have to get it checked for another two years also i know the guy that does it. I may just leave it and remove the two precats and mufflers.
Old May 3, 2007 | 09:07 AM
GIJoe's Avatar
GIJoe
Just make sure you hang on to it all in case you need it. It's "illegal" to remove that garbage...even though its restrictive crap.
I left all my stuff in place, I just rammed it empty. Its 100% there if you look under the car, but its all hollow.
I wanted to get a straight pipe too, but the C4 Vette mechanic I used to take my car too said that I won't be gaining much over the already rammed out cats. It adds a bit more of a raspy sound, but I actually like it.
Old May 3, 2007 | 02:49 PM
PBnf's Avatar
PBnf
I'm in the process of assembling the parts for just the system you're describing. So far I only have a set of Hedman Elites. What do you recommend for the cats, and x-pipe?. I have a 90 Coupe. I hope this doesn't hijack your discussion thread. I am hoping to add to it.
Old May 3, 2007 | 02:55 PM
Demonic85's Avatar
Demonic85
I ripped all that stuff out of there, hehe.
Old May 3, 2007 | 03:03 PM
BADDUCK's Avatar
BADDUCK
PBnf
Are you wanting to eliminate the main cat with a x-pipe? If so, you will need 2 bullet cats on two fabbed pipes that replace your original front Y-pipe and terminates in the X. Another way is replace your main cat with a hi- flow main cat, then cut off your front Y behind the two precats and extend the pipes forward into the header flanges. Either way it's pretty much custom welding. There are other options.
Old May 3, 2007 | 03:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Get a pair of hi-flow 3" bullet cats. I believe they can be had in the 450cfm range.
This 900cfm total flow would support a little over 400hp at the crank.
With true duals an Z-pipe would add a little too. To locate the "X", paint stripes down the pipes and run the engine till you see paint burnt or heavily discolored. Install the "X" at the center of the discoloration.
Old May 3, 2007 | 07:46 PM
PBnf's Avatar
PBnf
To locate the "X", paint stripes down the pipes and run the engine till you see paint burnt or heavily discolored. Install the "X" at the center of the discoloration.[/QUOTE]
That's interesting. I've never heard of that method. I'll try it. Right now I have the headers. I'll get 2 cats next. Then finally when my budget allows, the pipes and x-pipe. Just one more thing, the cats come right after the collectors, right?
Old May 3, 2007 | 08:03 PM
CentralCoaster
I've heard this quite a few times, but never seen an explanation for it. Do you have any insight?
Old May 3, 2007 | 08:25 PM
N.C. Kid's Avatar
N.C. Kid
To Main Cat Question
