knock counts and fuel octane level
The things i have done so far is lowering the fan speeds and changing the injector constant.
I have also removed the 1-4 skip shift.
After that i have done 2 loggings and adjusted the VE table with VEmaster and it is getting better.
I guess i have few more runs before i´m pleased.
The thing that annoys me is the knock counts which still is there.
Will my final VEtable tuning fix the knock count problem or do i have to adjust the Sparktables ?
Maybe if i buy higher octane fuel it will help ,any ideas ?
Here is my latest TTS scan ,which i know is abit rich on fuel.
http://www.holmsund.nu/jakobsson/pelle3.uni
Pelle
-90 vert ZF6
The throttle response is very smooth and nice.
Tuning is very rewarding.
Pelle
-90 vert zf6
Ill have a look at your log file soon (might not be tonight though)
Then id scan again, and everytime you get a knock like youre getting, pull out 1 or 2 degrees from the spark advance table that is in use at the time of the knock, then scan it again and see how it goes.
P.S. Youre LT counts look pretty good to me, around 120-124 seemed to be pretty consistant, im not sure what youre number aiming for but that is reasonable. Maybe try getting it as even as you can at 121 and do another file aiming for 124 and see which one you feel works best for you.
Rotor and cap is new as well ,becuse somebody had put cheap aluminium cap on it.
Runs very nice.
I haven´t checked the base timing but i will ,good tip.
Is that done the old fashioned way with timing light and markings ?
How many degrees is the original setting ?
The interesting thing about my tune is that i think the new injectors don´t have the same linearity as the old ones.
Since all injectors use a coil i think that a retune (VE) is needed when size/brand is changed due to linearity.
My injectors was bad when i bought my vette last year so maybe what i explain as "runs nice" now is what other people is experiencing all the time.
Pelle
-90 vert ZF6
If the injector brand you used are different the the originals then the flow rate might be different, probably due to the fuel pressure they rate the injectors at. Ford injectors are rated at abit lower pressure.
