ABS lite
Old May 3, 2007 | 07:40 PM
GM Junkie's Avatar
GM Junkie
Default ABS lite
Howdy - My first post to the Tech Forum, here's my issue: (Well, at least ONE of them!)
When I first turn on ign. - all lites (incl ABS) lite up as they should.
Manual says that after I start, ABS lite should flash, indicating ABS is functioning - then when I put trans in Drive, ABS Computer will "burp" as I move off......Well, I get the "burp" , but no ABS lite flash. Pedal does feel a little hard when braking but other than that, system appears to be functioning.
Should I be looking for a problem here?
TIA
Old May 3, 2007 | 08:04 PM
IRAraid's Avatar
IRAraid
Default ABS light
My '95 performs as you describe. The ABS light stays on for a second or two, but no flash. And I can feel the 'burp' occasionally but not always. My mail box has one lane of gravel, the other black-top. I test the ABS by jamming on the brakes at the mail box. Always works.
Hope this helps.
Old May 3, 2007 | 10:33 PM
GM Junkie's Avatar
GM Junkie
Thanks, IRA. Hope that test keeps workin' for 'ya - otherwise you might be sportin' the mailbox as a new hood ornament!
To ABS lite
