iac gasket
Old May 4, 2007 | 10:39 AM
8888vette's Avatar
8888vette
Default iac gasket
Guys i am about to clean my throttle body and IAC were can i purchase new gaskets for both...........................
thanks
Old May 4, 2007 | 11:05 AM
rick lambert's Avatar
rick lambert
can't purchase the IAC alone, but I think it comes with the TB gaskets, any good parts store...like NAPPA, just ask. Well, on second thought, you MAY be able to get an IAC from a stealership, check the parts stores to confirm what I believe.
Old May 4, 2007 | 11:28 AM
rickneworleansla's Avatar
rickneworleansla
I also need TB gaskets. Especially the one under the plate. I couldn't find one at a parts store last I checked. I left it off. That was about a year ago. Let me know where you find it at. I know a local dealership should have it but I don't usualy buy parts from them.
Old May 4, 2007 | 12:54 PM
RRT vette's Avatar
RRT vette
Purchase a new IAC (just to get the gasket), a complete TB gasket kit (should have the IAC gasket), or make one from gasket paper.
Old May 4, 2007 | 01:49 PM
ruffneckxx's Avatar
ruffneckxx
Cruise-In VI Veteran
St. Jude's Donor '06
I was under the impression you didn't have to change the gasket if you were careful.
Old May 4, 2007 | 01:51 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Just make one from gasket paper and an X-acto knife like I did. Use a dab of motor oil on the back of the gasket before bolting it back to the TB to ensure the formation of an airtight seal.
Old May 4, 2007 | 05:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I use ~1/26" thick sheet gasket material so it has some compressability.
Old May 4, 2007 | 06:27 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
St. Jude Donor '12
NAPA has the full gasket kit for the rebuild including the IAC gasket
Old May 4, 2007 | 06:38 PM
Vette Gator's Avatar
Vette Gator
Autozone also has the complete gasket set for about 6 bucks.
Old May 5, 2007 | 11:50 PM
klkordzi's Avatar
klkordzi
I tried Autozone, Advance and NAPA. Nobody had the IAC gasket. Everyone had the throttle body. I ended up using a sheet of gasket material and some silicone sealer
Old May 7, 2007 | 11:47 AM
8888vette's Avatar
8888vette
Default iac gasket
guys i whent today to rockauto.com and i purchase the set of gaskets for 8.99
STANDARD MOTOR PRODUCTS Part # 2009 {THROTTLE BODY GASKET PACK}
To iac gasket
