As soon as I turn my key forward (before the car is even started) the fans will turn on. I have no idea where to begin and I couldn't find any information on this. This is for a 93 C4, by the way. Thanks!
Check to see if the 2-wire switch is plugged into the A/C pressure line.
If it is, remove the connector and verify that the switch is closed by measuring resistance across the contacts is zero.
I ran the codes and it came up with code 28. According to another website:
Air conditioning Clutch relay and/or cooling fan relays. Check with digital Ohm meter, replace if less than 18 Ohms. If relays OK, potential ECM failure.
So, is this the connector you are talking about? The only two wire connector I could find on the AC line was by the dipstick, right next to the stainless steel braided fuel lines. It looks like removing it would let gas escape. I am going to need a better description of its location if that isn't it.
