need lt4 rocker arm torque spec please
Old May 6, 2007 | 10:41 AM
bent's Avatar
bent
Default need lt4 rocker arm torque spec please
I am changing valve springs at my dad's house and forgot my FSM. I do remember that when setting "lash" that it specified to torque the rocker nuts instead of the usual tighten untill the pushrod won't spin + 1/2 to 3/4 turn. can anyone look up the spec/procedure for me???? thanks so much
Old May 6, 2007 | 10:42 AM
Pete K's Avatar
Pete K
With the valve you are adjusting closed, and the cam lobe on the base circle, zero lash + 1/2-1 full turn is fine.
I normally go 3/4 turn.
Old May 6, 2007 | 11:05 AM
bent's Avatar
bent
thanks, pete. I feel pretty safe doing the usual method, but I wonder why the factory service manual had a torque spec???
anyone??
Old May 6, 2007 | 11:07 AM
Pete K's Avatar
Pete K
anyone??
I have never seem a torque spec listed on a gen 1 sbc.
Possibly you are thinking of the rocker stud torque?
Old May 6, 2007 | 11:34 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Unlike the LT1 and other SBC engines, the LT4's rockers are not adjustable. I'll see if I can find your torque spec.
Here we go, 18 lb.-ft.
Old May 6, 2007 | 12:08 PM
bent's Avatar
bent
thanks, kid!!
Old May 6, 2007 | 12:15 PM
bent's Avatar
bent
I did forget to mention....I do have the hot cam....would this affect the required torque?
Old May 6, 2007 | 12:47 PM
STL94LT1's Avatar
STL94LT1
No.
To need lt4 rocker arm torque spec please
