Fuel pump won't work??????
Old May 6, 2007 | 08:04 PM
1990Vet's Avatar
1990Vet
2nd Gear
Default Fuel pump won't work??????
I bought this beautifull 1990 l98 6 months ago drove maybe 50 mile crapped a head gasket. I pulled everything apart and put the new set in took all of about two weeks. Now The fuel pump won't kick on. The fuse in passenger side fuse compartment has been replaced. I swapped out the radio relay with the fuel pump relay still no pump action. I have no fancy tool to check the computer. Can anyone tell my how to make to pump run with out changing around the oil presure switch?
Old May 6, 2007 | 08:24 PM
CFI-EFI's Avatar
CFI-EFI
You can power up the pump to be sure it hasn't failed by jumping 12 volts to terminal "G" of your ALDL.
RACE ON!!!
Old May 6, 2007 | 09:15 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default pump
(that's the lower row, and all the way to the left)
Old May 6, 2007 | 09:40 PM
Repzard's Avatar
Repzard
Yes G is the first one on the second row
Apply 12 volt to that plug just like CFI-EFI said and fuel pump should run
good luck
Old May 6, 2007 | 11:39 PM
RRT vette's Avatar
RRT vette
As long as the wiring to the fuel pump and connections are good, when you apply 12v to terminal G of the ALDL...the fuel pump should run. You can test the connector at the fuel pump. It should have battery voltage. If it does and the pump still doesn't run, consider the pump or connection to it faulty.
Old May 8, 2007 | 04:47 AM
1990Vet's Avatar
1990Vet
2nd Gear
Thank you for the help so far! I powered the G post on the adl. pump still won't work. I will find the connector to the pump and test it.
Old May 8, 2007 | 02:04 PM
CFI-EFI's Avatar
CFI-EFI
Also, the fuel pump fuse is between terminal "G" and the pump.
RACE ON!!!
To Fuel pump won't work??????
