Header Comparison; (Poll)
Old Oct 20, 2001 | 04:10 AM
BlackRocket's Avatar
BlackRocket
Default Header Comparison; (Poll)
Which Header gives the best performance / durability ???
Old Oct 20, 2001 | 05:09 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Header Comparison; (BlackRocket)
Got to go with Jeal. Things are a work of art.
Old Oct 20, 2001 | 09:35 AM
Hammer's Avatar
Hammer
Does Jeal make headers for LT1's
Old Oct 20, 2001 | 10:10 AM
LT401Vette's Avatar
LT401Vette
If you are not considering cost or easy access LPE headers are solid well designed units. However, they had only performance and durability in mind when they designed them. It's a whole lot easier to work on a car with Hookers(ie change spark plugs, and you save quite a bit aswell. TPIS quality and performance design is lower, but cost is high, quality low, performance mid stream and convenience between LPE and Hooker.
[Modified by LT401Vette, 12:38 AM 11/3/2001]
Old Oct 20, 2001 | 10:35 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I've got the TPIS.
Old Oct 20, 2001 | 11:54 AM
AS84's Avatar
AS84
Default Re: Header Comparison; (Jeffvette)
That jeal is a good looking header. Whats with the 4 bolt holes per exhaust port?
If you run hookers don't you have to scrap all of the egr/ air stuff or is that just a hedmann?
Old Oct 20, 2001 | 12:00 PM
scorp508's Avatar
scorp508
Default Re: Header Comparison; (AS84)
Those are ZR1 headers. And some of the hookers have the EGR/AIR stuff.
Old Oct 20, 2001 | 12:02 PM
AS84's Avatar
AS84
Default Re: Header Comparison; (scorp508)
Gotcha, didn't realize it was a ZR1.
Old Oct 20, 2001 | 01:29 PM
Andy1983's Avatar
Andy1983
Why would anyone settle for 2nd best when you are talking about a Corvette?
TPIS is a better bang for the buck, but that isn't the question. The question is... which is the BEST?
Go with the best known brand, and the longest existing brand, and without a doubt the BEST brand- Hooker.
Can't beat 2 3/4 Super Competition BadAzz headers.
Go with the best, spend the extra $.
Old Oct 21, 2001 | 03:25 AM
Jeffvette's Avatar
Jeffvette
Default Re: Header Comparison; (Hammer)
Nope Geoff Jeal was part of the internal project on the ZR-1. He makes headers, cams and a few other parts for the LT5.
Old Oct 21, 2001 | 09:25 AM
RichS's Avatar
RichS
I have DRM Longtubes on the GS. They fit great, Look good, And perform good. They were pretty much a bolt in mod!
Old Oct 21, 2001 | 10:35 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Header Comparison; (RichS)
This survey is intended to find out the best brand of header for what type of Corvette motor? I think the intended application needs to be clarified.
[Modified by Red 90 L98 Coupe, 8:36 AM 10/21/2001]
Old Oct 21, 2001 | 11:37 AM
ezmoney92's Avatar
ezmoney92
Default Re: Header Comparison; (Red 90 L98 Coupe)
Hooker super comps coated by Jet Hot. :)
Old Oct 21, 2001 | 01:06 PM
Stratocaster's Avatar
Stratocaster
Default Re: Header Comparison; (ezmoney92)
With the LT1 engine, typical peak RPM for many is at 6500... you need as long of a header design as you can fit in the C4... Study up on your header design theory. It will help you make the decision.
I compared alot of header designs. Best thing to do is to get as many picks as possible and scale them so that the bolt patterns are equal length. Then overlay the pics so that you can measure header tube length and collector design. You will find many do not have optimal tube lengths & collector design as they profess..... A difference of a couple inches means alot when it comes to scavenging.
My choice was....
Exotic Muscle Long Tubes - good fit, design, materials and price. It didnt have all the features I wanted but the 80/20 rule was applied. The major objectives met. One thing I didnt like was the raised "O'ring" designed flange. But no leaks to date. Second thing that the turnaround wasnt the best.
Process Coatings (Michigan) - Acid bath, Internal - exhaust duty "Green Coat", External - "Cermakrome". Highly recommend these good people. They have the best process and coatings out there. Hence their name.
Old Oct 22, 2001 | 09:06 PM
BlueC4 LT1's Avatar
BlueC4 LT1
Default Re: Header Comparison; (tntcorvette)
how much are all these headers? which is cheapest/most expensive? How much does a shop charge you to put them in, what kind of performance gain do you get? do you feel it? hear it? love it? :hat
Old Oct 22, 2001 | 11:52 PM
ezmoney92's Avatar
ezmoney92
Default Re: Header Comparison; (BlueC4 LT1)
Hooker super comps coated by Jet Hot-----$430 from Jet Hot direct. Shops go anywhere from $500 and up. Took me 14 hours with a helper and a lift. ( also did serp belt, water pump, plugs, wires, coil, converters, opti, O2 sensors, and fuel filter just to name afew ) :seeya
Old Oct 23, 2001 | 12:09 PM
Mojo's Avatar
Mojo
:eek: Good God!! It only took me a few hours with a helper and jackstands! The Hooker install is very easy!
To Header Comparison; (Poll)
Old Oct 23, 2001 | 06:45 PM
ASRoff's Avatar
ASRoff
Default Re: Header Comparison; (Mojo)
The exotic muscle headers are a work of art as I have said in previous posts they have both O2 sensor bungs and EGR hookup. (its not drilled so you can decide if you want egr or not great for LT-4 intakes) :chevy
Old Oct 23, 2001 | 09:28 PM
TOEMAN's Avatar
TOEMAN
Default Re: Header Comparison; (ASRoff)
tpis from the headers through the cat are great, installation a joy. there cat backs suckkkkk. nothing lines up, you will need a torch for their cat back system.(3 1/2" to 3" y pipe and 3" flowmasters) but they sound great!!!
Old Oct 23, 2001 | 11:38 PM
ezmoney92's Avatar
ezmoney92
Yep, 14 hours was about it. Took about 1 hour just to cut and reconnect the passenger side EGR tube to fit into the header. I think we probably spent an hour just re routing the plug wires. :) I guess it was probably closer to 10 hours but was still a pain in the a**! :yesnod:
