We know from experience that a higher-ratio rocker makes more power in engines that would normally need a bigger (higher lift/more duration) cam. But we weren't able to prove it this time. After installing the 1.6s we were shocked when the engine dropped more than 40 hp! As we explained earlier, rocker arms increase the ratio by moving the pushrod cup closer to the rocker fulcrum pivot point. That's where our problem was. The pushrod was contacting the top of the clearance hole in the cylinder heads with the 1.6 rockers. So, you can see that swapping rocker arms involves more than just deciding what ratio to run. In fact, this problem is very hard to spot because it's typically hidden beneath the pushrod guideplate, which is why it took us a while to find it.
Westech came to our rescue, however, and dug up some old dyno tests comparing 1.5s to 1.6s on other small-blocks. Those results found the 1.6 rockers making more than 20 hp over the stock 1.5 rockers. But that engine was equipped with a smaller cam than this one, and it seemed to really need the additional lift and duration afforded by the higher ratio.
That was interesting... I like doing all the research I can before buying my upgrades. I like to upgrade once
As far as additional power... I'm really not too worried about it, but it's never a bad thing to gain either. So going 1.52 or 1.6 is not a huge concern to me since I'm just cruising most of the time.
