fluid damper??
Old Oct 20, 2001 | 02:12 PM
miker61588's Avatar
miker61588
Default fluid damper??
where can i find one? are they really worth it? is true that my engine is externally balanced?
[Modified by miker61588, 12:15 PM 10/20/2001]
Old Oct 20, 2001 | 02:41 PM
AS84's Avatar
AS84
Default Re: fluid damper?? (miker61588)
I bought one for my other car and was told by a machinest that the crank would have to be re-balanced for the new dampner. It also weighed much more than the stock dampner but I guess thats good when the rpms are already up.
Old Oct 20, 2001 | 08:23 PM
Mad Maxwell's Avatar
Mad Maxwell
Miker,
I went through this exercise back in April so I think I can help. At first, I bought an external balance Fluidamper but that turned out to be wrong. I think it's for 383's and 400's and their variants. Our stock displacement 350's are internally balanced on the front and externally balanced on the back. They have a neutral balancer and a counterweighted flywheel.
I chose the streetdamper from Summit because I wasn't racing and it seems to smooth things out in the upper RPM ranges.
Best of luck,
-Max
Old Oct 20, 2001 | 09:34 PM
miker61588's Avatar
miker61588
Default Re: fluid damper?? (Mad Maxwell)
thanks for you help guys
To fluid damper??
