block learn
Old May 8, 2007 | 09:29 PM
dagrump's Avatar
dagrump
Default block learn
i borrowed my buddies snap on scanner tonite because my car has had some intermiting surging at idle. there were no codes stored but my block learn went down to 98 . i checked my fuel pressure which was 38psi with vacuum hose disconected. sprayed starter fluid on the intake and all vacuum hoses to check for leaks. i recently did a full tune up . the o2 sensor was going into closed loop. what causes the blms to go rich or lean. any advise would be greatly appreciated.
Old May 8, 2007 | 09:34 PM
scorp508's Avatar
scorp508
38psi with no hose? What year is your car, that is most likely way too low.
Old May 8, 2007 | 09:48 PM
dagrump's Avatar
dagrump
my car is a 1991
Old May 8, 2007 | 09:51 PM
bmalec's Avatar
bmalec
Which fuel injectors are you running? If your BLM values are that low, the ECM is trying hard to lean things out. Also, are you running an adjustable fuel regulator?
Ben
Old May 8, 2007 | 09:57 PM
dagrump's Avatar
dagrump
i am running a adjustable fuel pressure regulator. i believe they are the stock multechs.
Old May 8, 2007 | 10:09 PM
bmalec's Avatar
bmalec
Odd--not sure why your BLM values would be so low with stock injectors. Perhaps you have a leaky injector or two?
I'm sure others will chime in with some good suggestions, but I'd suggest verifying that the injector resistances are good (16-17 ohms) and also read your sparkplugs to see if any look out of whack.
If the injector and plugs look good then hmmm.... vacuum leaks would cause your BLMs to go up, not down, so I wouldn't suspect those.
Ben
Old May 8, 2007 | 10:20 PM
Demonic85's Avatar
Demonic85
Fuel pressure sounds good to me. Should be between 36 and 41 psi for an L98, higher for an LT1.
Old May 8, 2007 | 10:53 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Have you checked for exhaust leaks? ECM is adding fuel because O2 is registering lean.
Old May 9, 2007 | 10:25 PM
dagrump's Avatar
dagrump
i did check for exhaust leaks. i tightened header bolts and checked entire exhaust. it's funny, it does not do it all the time and sometimes worse than others. i'm puzzled. if it did it all the time it would be a vacuum leak or something. it has not thrown any codes. i'm going to pull the o2 sensor tomorrow to take a look at it.
Old May 9, 2007 | 10:39 PM
dadsC4's Avatar
dadsC4
Default Injector Balance Test?
Have you tried an Injector Balance test? That should tell you if you have one sticking or leaking. There is a special tool you will need but it proves quite useful once you have it. It is GM multech specific.
Old May 9, 2007 | 10:44 PM
dadsC4's Avatar
dadsC4
Default Field Test Mode
Another thing you can try is putting it in Field Test Mode. If you have the Snap-On Brick (mT-2500) you should be able to OBD1 Gm vehicles into ths mode. I think it is found in functionality tests. When you put it in this mode it bypasses all computerized parameters, kinda eliminates the computer. GM had issues with PCM's and this allows you to eliminate it. If the vehicle acts normally (problem goes away) you could suspect the PCM. It's just a real quick and easy test you can do with the brick.
Old May 9, 2007 | 11:40 PM
SunCr's Avatar
SunCr
Should of thrown a Code that rich and ran like crap. Was it only momentary? My guess would be a leaking injector.
Old May 10, 2007 | 12:33 AM
RRT vette's Avatar
RRT vette
The BLM should have not gone down that low unless the chip has been tuned for it. I belive 108 is the lower limit in a stock chip. The fuel pressure sounds low with the vac line off. Usually (depending on vaccum pressure) the fuel pressure will increase by about 5 psi with the vac line off. That means you are at about 33 psi with the vac line on.
Check for exhaust leaks before the O2 sensor, check that the AIR system is diverting the air to the catalytic converter, and check the vac lines around the engine again. Vac leaks will introduce unmetered air into the exhaust stream and cause the O2 sensor to send a lean signal to the ECM. The ECM will add more fuel to compensate, thus a rich condition.
Old May 10, 2007 | 01:47 AM
SunCr's Avatar
SunCr
Just the opposite - unmetered air is picked up by the O2 as a lean condition - BLM's are above 128. The ECM adds fuel and it runs too rich. You'll see at the tailpipe, but not on a scan - BLM's will be lean, not rich. With this result, the ECM should be reducing pulse width, not adding it. That extra fuel can only come from a couple of sources - the injectors, bum regulator, or a broken evaporative emissions system.
Old May 10, 2007 | 08:09 AM
Z06_BluByU's Avatar
Z06_BluByU
Old May 10, 2007 | 08:22 AM
anesthes's Avatar
anesthes
98 blm is pig rich, ecm is taking away fuel Dom.
-- Joe
Old May 10, 2007 | 08:24 AM
anesthes's Avatar
anesthes
I think his scanner is bum.. You are dead right about the 108blm being the bottom on the stock bins. I think 108 and 160 is the boundries.
-- Joe
To block learn
Old May 10, 2007 | 08:31 AM
ittlfly's Avatar
ittlfly
Correct. However his BLM is @ 98. The ECM is not in control (BLM below 108). Therfore the O2's are living above 450 mv seeing a rich exhaust stream. The short term intergrator can't adjust and the long term fuel trim is being skewed to the left as a result. the ECM tries to remove the extra fuel to compensate but is beyond the computer's control.
How old / milage are on the O2's? I"d start there to be sure the ECM is recieving a true value from the O2's.
Old May 10, 2007 | 08:40 AM
anesthes's Avatar
anesthes
Hrmm.. I thought 108 was the threshold for correction. Are you saying it gives up and throws in the towel ?
-- Joe
Old May 10, 2007 | 08:56 AM
ittlfly's Avatar
ittlfly
-- Joe
I too thought that 108 was the bottom figure for the ECM according to the FSM. Apparently not. With a 98 reading the ECM clearly is not in control of the A/F mixture. That's why I *suggested* that he needs to be sure the ECM is seeing a true value of the A/F being reported by the O2's.
