Leakage at Low Coolant Sensor
Old May 8, 2007 | 11:27 PM
Wheelman's Avatar
Wheelman
Default Leakage at Low Coolant Sensor
I just put in my replacement radiator and noticed that its dripping where the low coolant sensor is. I didnt see any kind of gasket or seal on this thing when I put it in or when I took it out of the old radiator...is there one I am missing possibly? It seemed like the hole was slightly bigger on the replacement radiator, but close enough that I thought it might work, but anyhow, has anybody had this problem before? Just wondering if there is a good way I can keep it from leaking here without just plugging up the hole.
Old May 8, 2007 | 11:37 PM
Megabite's Avatar
Megabite
3rd Gear
Just replaced the rad on my '87 and the low coolant sensor had a little rubber o-ring on it.
