1984 vette antennea wont move
Old Oct 20, 2001 | 04:03 PM
IceDigger's Avatar
IceDigger
Default 1984 vette antennea wont move
One day I was driving along and turned the radio on, the antennae went up halfway then just stopped and I can't seem to get it down. Because of this I cannot turn the radio on or use my cd player since I am guessing everything is hinging on getting the antennea up. Any clue what would be wrong? Easy/cheap fix?
Old Oct 21, 2001 | 12:28 AM
IceDigger's Avatar
IceDigger
Default Re: 1984 vette antennea wont move (IceDigger)
bump
Old Oct 21, 2001 | 05:25 AM
HWoods's Avatar
HWoods
My 84 is on it's third antennea. There is a cable in there that moves the antennea up and down and they break. I have seen the cables for sale, but could not make the repair work, so just bought a new antennea from http://www.tld-corvette.com and replaced it. Good Luck
Old Oct 21, 2001 | 08:01 AM
rnelson11's Avatar
rnelson11
I've replaced the cable before, but not on my Corvette. Most are nylon, kinda like grass trimmer line. I'd at least give it a try. Worst case you have to buy a new antenna.
Old Oct 21, 2001 | 08:03 AM
rnelson11's Avatar
rnelson11
Buy the way, if the cable is broken you should be able to pull it all the way up. Then you can disconnect the motor (leave the antenna cable connected) and use your radio.
Old Oct 21, 2001 | 01:33 PM
IceDigger's Avatar
IceDigger
Default Re: 1984 vette antennea wont move (95Vette&2000SS)
Cant forcefully pull the antennae up or down :(
Old Oct 21, 2001 | 03:08 PM
rnelson11's Avatar
rnelson11
You say you can't play the radio. What happens when you turn it on. Have you checked the fuse?
Old Oct 21, 2001 | 03:37 PM
IceDigger's Avatar
IceDigger
Checked the fuse, its fine.
The radio looks like it is playing but no sound comes out.
Old Oct 21, 2001 | 04:53 PM
wilb3's Avatar
wilb3
Odd, you should be getting some sound regardless of the antenna going up or down. Could be amp related.
To 1984 vette antennea wont move
