Do I need a different belt? (pic)
Old May 9, 2007 | 03:02 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Do I need a different belt? (pic)
Since I have no AC on my car and just installed an underdrive crank pulley, it's been trial/error finding a belt that fits. The current one I'm using seems to work fine, but looking at the tensioner marks I'm not sure if it has the proper tension.
Do I need a different belt, or is the tension on this one ok?
Old May 9, 2007 | 03:06 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
If you can press on the top of the belt, longest open section, and the belt depresses more than 1/2-3/4" down, you need a different belt. Use a cloth tape and run it around, prop the tensioner mid way, and use the inches to match to a belt...
Old May 9, 2007 | 07:45 PM
FlyboyZR1's Avatar
FlyboyZR1
Yeah I was able to push down about 1" on that belt, went to NAPA and picked up one just a bit shorter and it fits much better, thanks for the help.
To Do I need a different belt? (pic)
