which L98 gaskets do i need
Old Oct 20, 2001 | 05:30 PM
james holley's Avatar
james holley
Default which L98 gaskets do i need
ill soon be installing a lingenfelter intake manifold, asm runners and ported plenum. what gaskets do i need and wheres the best place to get 'em? thanks :D
Old Oct 21, 2001 | 01:17 AM
jfb's Avatar
jfb
Default Re: which L98 gaskets do i need (james holley)
Install Fel-Pro teflon coated gaskets. Factory ones last about 2 yrs max and then split and start leaking coolant, Fel-Pro's don't fail.
Old Oct 21, 2001 | 03:31 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the ASM runners are LT, you can get a larger set from TPIS or just take a Dremel and sanding drum to the stock ones that come in the Fel Pro topend kit.
You will need some black RTV for the manifold ends and some non-hardening thread sealant for the manifold bolts.
To which L98 gaskets do i need
