Going to 'change the chunk'
Old May 9, 2007 | 08:07 PM
aminnich's Avatar
aminnich
Default Going to 'change the chunk'
First, I do have the full set of FSMs. Second, I have not read up on this yet, but will before I start.
Project is to drop out the 2.59 diff (chunk) and slap in a 3.07. It looks like actually disconnecting and dropping the exhaust out of the way might be the hardest part, but at least I don't have any heavy mufflers hanging on there.
ANY GOOD SHORTCUT TIPS??????????????????????????
Thanks in Advance.
Old May 9, 2007 | 09:16 PM
Pete K's Avatar
Pete K
Be sure to remobe the 2 bolts on each camber rod bracket and loosen the nut at the spindle to prevent the need for realignment. Do not loosen the cam bolt
Old May 9, 2007 | 10:38 PM
BlackC6LS3's Avatar
BlackC6LS3
This should help you.
To Going to 'change the chunk'
