86' wheel speed sensor ????
Old May 10, 2007 | 01:51 PM
Shimy86's Avatar
Shimy86
Default 86' wheel speed sensor ????
Before I dig in to far, I'll ask and save some grief. looked at all 4 sensors last night and no suprise, all look the same. The wires seem to run off to god knows where. Where is the connection for replacement and can a dealer check them once removed to find bad one?
Old May 11, 2007 | 12:25 AM
86PACER's Avatar
86PACER
ABS light on?
You mean ABS sensor at each knuckle? The front ones each connect to a plug that is at the front center of the car, against the front crossmember. By the steering rack. PITA to reach. Must be done from the bottom with front raised.
Old May 11, 2007 | 10:13 AM
Shimy86's Avatar
Shimy86
Thanks Yeah the light is on sometime, off sometimes. Can a dealer check these if they are removed to see if they are working?
Old May 11, 2007 | 02:14 PM
86PACER's Avatar
86PACER
Have you done any electrical checks thus far? Do you have the GM shop manual? If not, I'd hold off on removing the senders. You might not even need to. Insted of pulling them, you can do a simply and quick ohm test on each one from within the ABS harness connector inside the cargo area where the wiring to each one ends and begins. The GM shop manual shows you which pins to check and what the readings should be.
Forum member Agent 86 might have the ABS section of the book in PDF.
For now you can use this:
http://www.corvettefever.com/howto/19239/
Is you brake fluid level topped off to the max line?
Old May 14, 2007 | 12:42 PM
Shimy86's Avatar
Shimy86
Thanks Pacer! I'll check these relays tonight, I stopped at the dealer and found out the wheel speed sensors are discontinued so I'm praying I have a bad relay....they are probably discontinued also!
Old May 14, 2007 | 03:31 PM
86PACER's Avatar
86PACER
The relays are not discontinued. PM Agent 86 and ask him if he can send you the ABS section of the Shop Manual.
To 86' wheel speed sensor ????
